To delete old text messages from your Android phone, the easy way is using Android data manager. After you link your Android phone to pc via usb cable or wifi, Android data manager will scan out all data on it, including the old text messages. Then you can preview and choose them to delete. https://www.coolmuster.com/android/delete-text-messages-on-android-phone.html
Go to message - inbox - pick the old message, press option then delete. All the old message will be erased. If its Nokia go to message - delete message - select the from the options (All read, inbox, drafts, sent items). Thanks
From the base
Press (erase)f during message playback.
• The current message is deleted.
From the handset
During message playback, press OK
to enter the options menu.
Select DELETE. Press OK.
Deleting all old incoming messages
From the base
Press and hold (erase) during standby.
• All old messages are permanently deleted.
From the handset
Press (menu)
Select ANSWER MACHINE >
DELETE ALL. Press OK.
• The handset displays a confirmation
request.
Press OK to confirm.
deleted.
Note
Unread message(s) cannot be deleted,
and deleted message(s) cannot be
recovered.
Hello! The answering machine will automatically save messages if you do not delete them; Even in the event of a power failure. It can hold 15 minutes of messages. After 15 minutes machine will "wrap" writing over the oldest message. An old message (listened to) can be deleted by holding erase for more than two seconds. Pressing Mailbox X (1-3) will delete all Old Messages in that box. Once deleted they are gone forever...
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
Go to Menu--message--inbox--open up the message which u want to delete n then press the option button---u will see Erase/Delete as an option then click OK.Again press OK if asks for confirmation.That's how u empty your inbox.
If u want to delete all the inbox messages then for that also you have an option in the inbox.
Just don't forget to press the "Option" button if u have to see the function.
go into message menu highlight message press the menu key(next to talk button) should give you several oprtions scroll down to delete the press trackball should prompt DELETE ITEM select delete all done
