Question about Jabra T-Mobile Wing / Dash / SDA / Sidekick 3 / Sidekick LX - Brown / Sidekick LX - Blue MOBILE/CELL PHONE... (BLUETOOTH-100) Transceiver
How do you put the bluetooth in discovery mode?
Posted by stephensmich on
Cableg Eye
  • 22 Answers
Normally you will turn the unit off by pressing and holding the call button for at least 5 seconds. Then when turning the bluetooth device back on you will press and hold the button 5 seconds to be discoverable. Good Luck.
Posted on Oct 09, 2009
My bluetooth isn't work...my windose is 7...when i turn bluetooth of my cellphone and my laptob my cellphone found it but the laptob bluetooth couldn't find it.
Hello, the reason your laptop cannot find your cellphone is becaus the cellphone's bluetooth is not in discovery mode. You will need to put the cellphone into discovery mode. To do that, open your bluetooth settings, and choose discovery mode or something like that. Then have the laptop look for new devices.
Thanks for using FixYa!
Jul 01, 2011 | Computers & Internet
How to program my bluetooth to my cell phone
Depending on the phone, You need to set your phone's bluetooth on the discovery mode. Once that is done, your bluetooth device should have a discover mode also (again, depending on the model). Once both are in discovery mode, they should find each other and pair with one another. Some devices will require for you to put in a code but many do not.
Mar 05, 2011 | Cell Phones
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My Bluetooth cannot paired with my iPhone
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Dec 13, 2010 | Blueant Z9i Bluetooth Headset
How do I pair my HFS100 with my new apple iphone
Dec 09, 2010 | Jabra Bluetooth Car Kit with Night Driving...
I am having trouble getting my 6230i to pick up my bluetooth headset.
you have to put the Bluetooth in pairing Mode and put the Phone in Discovery Mode also.
to put your bluetooth in discovery Mode - press and hold the middle button for about ten Seconds and when it starts flashing - or stays on a Sold Color ( red or Blue ) depending on the bluetooth. - - that means it is in Pairing mode.
hope this helps
thanks
Mar 31, 2010 | Nokia 6230i Cellular Phone
I'm having trouble getting my Jabra bluetooth in discovery mode.
Hold down the power button until you get a steady blue light. This should put it in discovery mode
Oct 20, 2009 | Jabra VBT185Z Bluetooth Headset
How to put my n82 nokia into discovery mode
Go to your Connectivity>Bluetooth>My phone's visibility>change to "Show to all". That's it.
Sep 06, 2009 | Nokia N82 Cell Phone (Unlocked) - Silver
How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Jun 30, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra T-Mobile Wing / Dash / SDA / Sidekick 3 / Sidekick LX - Brown / Sidekick LX - Blue MOBILE/CELL PHONE... (BLUETOOTH-100) Transceiver Logo
109 people viewed this question
Top Jabra Computers & Internet Experts
ChinthakaJ
ChinthakaJ
RudeRude
Andrew Taylor
Andrew Taylor
Are you a Jabra Computer and Internet Expert? Answer questions, earn points and help others
