2002 Volvo S60 Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine is whistling loudly, and stops if i remove
Engine is whistling loudly, and stops whistlling, if i remove the oil filler cap? How much should this repair cost, aprox.?
Timmy L Costa
Level 2:
  • Expert 142 Answers
  • Posted on Oct 09, 2009
Timmy L Costa
Expert
Level 2:
Answers
142
Questions
Helped
155285
Points
516
I would have the converter checked for back pressure. if it is plugged it can cause excessive Engine pressure. if it is not plugged then you have excessive blow by or a malfunctioning PCV system it sounds like.
3helpful
3answers
Volvo s60 2004 makes a whistling noise and engine light says P0300 random/ multiple misfire
You have to diagnose an ignition problem,
since you have the PO300 & misfires shown,
at least for many cylinders
Could end up just being one cylinder or several
that need whatever ignition parts control them
Individual Coils for each cylinder or a module that
applies to all of them
Wouldn't use the car until resolved
As it gets worse, you will ruin the exhaust converter
No idea on the whistle
1helpful
Whistle noise
Start the car, open the hood, remove the oil filler cap off the valve cover, if the noise goes away, the problem is in the "positive crankcase ventilation" system (blown diaphragm).
Whistling sound from engine, 1993 400E
Remove oil filler cap and if noise stops, crankcase breather is blocked.
I want to check the engine oil level for previa 2.4 petrol 1995
OIL LEVEL CHECK Every time you stop for fuel, check the engine oil as follows:
  1. Park the vehicle on level ground.
  2. When checking the oil level it is best for the engine to be at operating temperature, although checking the oil immediately after a stopping will lead to a false reading. Wait a few minutes after turning off the engine to allow the oil to drain back into the crankcase.
  3. Open the hood and inspect the level of the engine oil tank. The fluid level on the tank should read between FULL or F and LOW or L.
  4. If the level is below the LOW or L line, remove the cap and add enough engine oil to reach the FULL or F line. Fig. 1: Fill the engine oil tank located under the hood first 90911p07.jpg
  5. Install the oil cap and hand tighten.
  6. After filling the oil tank, remove the engine access hole cover on the drivers side. Fig. 2: Make sure the oil tank is to the F mark 90911p15.jpg Fig. 3: The oil dipstick is located under the driver's side engine access hole cover 90911p83.jpg Fig. 4: Place your finger through the hole and pull straight up to remove 90911p84.jpg
  7. Remove the engine oil dipstick and wipe it clean.
  8. Reinsert the dipstick, push it in as far as it will go, the pull it out and look at the level on the end.
  9. If necessary, insert more oil through the oil filler cap next to the dipstick, this will completely top off the system. Fig. 5: The oil dipstick has two markings for level check 90911p85.jpg Fig. 6: To fill the crankcase, remove the engine oil filler cap 90911p86.jpg prev.gif next.gif
3helpful
5answers
Oil coming out of engine oil filler cap even though i have changed oil filler cap
The engine breather pipe seems to be blocked.
It may also damage the oil seals.
2002 s60 volvo whistles when car is running if i remove the oil cap whistling stops
The PCV valve may be plugged causing normally removed crankcase pressure to be pushed out of the oil cap. Replace the valve.
6helpful
3answers
S40 t5, check engine , whistling sound
Read my other posts to the same problem. if the noise goes away with the oil filler cap removed you need to replace the oil filter housing and hose. good luk
2answers
BWM 318 DRIVE BELT NOISE
bearing in the a-c ,sounds like it needs a new 1 .not a easy fix
3helpful
2answers
How do you change the oil filter on a Hyundai Accent 1998/99?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
