Question about Lands Phones
Landline is always busy
Telephone landline is always busy, even outside at the network box when checking with another phone
Posted by micmiester on
george peters
    President:
  • 860 Answers
If its still showins as a busy when the phones plugged in at the NId ( the box outside) then the trouble is showing towards the telco . Call your local provider for repair.
Posted on Oct 09, 2009
My landline is not working.
Here's the drill.
Call your telephone company, and they will check your service to the house or apartment.
From the box on the outside wall, the wires to your phone on the inside are your responsibility, meaning you would have to get someone to fix them your self.
However, at the outside connection box, there is a plug wherein you can plug a phone in to, and see if the signal is getting that far.
If it is, you need only check wires and connections between there and your inside phone.
One other thing.
I hope the 021 number you listed is not the number of your phone, because if it is, now many persons or businesses could copy that down and bother you.
Please do not publish your phone number where others can read that number, to save phone calls you do not wish to receive.
God bless your efforts.
Sep 03, 2018 | Miscellaneous
How do I get the silent mode off my phone ?
if you have a landline phone, plug that into the Demarc either inside/outside of your house, if you dont know what that is, its a grey box where your phone lines come in and you will see customer service side. Get a phillips screwdriver and open that side up and plug your phone in. If it doesnt ring there, your phone company has to fix the problem.
Apr 04, 2016 | Uniden DECT 6.0 Cordless Telephone...
Am getting Silent Mode On and New CID:49
Jan 28, 2016 | Uniden DECT 6.0 Cordless Telephone...
Where can i find a user manual for a TELKOM Business LKA 900 landline phone
Check if this is the one
http://www.mbc-comms.co.uk/wp-content/uploads/2013/04/SLT-POTS-phone-LKA-200-User-Guide-4web.pdf
Feb 23, 2015 | Lands Phones
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
Network busy message
problem with the network provider not the phone. call customer care and lodge a compliant
[email protected]
Jan 22, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
I'm unreachable
Hi your call divert might be active on your phone menu so i would go it and deactivate it!
Nov 01, 2007 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
414 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
