Question about JVC KD-G220 CD Player
How do I set the clock on my JVC KD KD-G220 car stereo
Posted by brianviscoun on
Anonymous
  • 59 Answers
JVC web site
Posted on Oct 09, 2009
9helpful
3answers
Change time on car radio model kd-g220
1. Press and hold "select" on the faceplate until the display changes.
2. Using the up/down rocker switch at the right of the faceplate, cycle through the PSM (Preferred Settings Menu) until you get to "Clock H".
3. Use the dial control (left end of faceplate) to select the hour. Note that it's not a 24h clock, just 1 to 12 are available.
4. Use the rocker switch to select "Clock M".
5. Use the dial to select the minute from 00 to 59.
6. Press "select" to return to regular operation; you may wish instead to use the rocker switch to cycle through other PSM options for the dimmer, scroll and woofer.
If you want more details then you can download the manual from JVC here.
I hope that you have found my posting to be of assistance, all I ask in return is that you return the favour by rating my answer. If you still have not solved your problem then add a comment instead and I'll offer further help.
Set clock on car stereo
If you press and hold the menu button, it will allow you to scroll thru options and one is set clock...turn the dial to adjust.
K
Time on radio
usually you would turn off the unit and hold the menu button for a fre seconds that will bring up a whole new set of options just scan through them and u should see adjust clock
Cant set the clock
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
HOW I CAN RESET THE CLOCK ON MY CAR AUDIO
Hi....
You can get the manual from here
Hope my info solves your problem....
Thanx for using fixya........
4helpful
How set time jvc kd g220
jvc kd g220
See page 10.
2helpful
Set Clock
  1. Hold the "SEL" button.
  2. Using the skip forward/backward buttons, select "Clock H".
  3. Use the rotary **** to adjust the hours.
  4. Using the skip forward/backward buttons, select "Clock M".
  5. Use the rotary **** to adjust the minutes.
Here is a link to the owner's manual, as a reference (Page 10).
2helpful
2answers
Car clock setting
For the JVC KD-G200 look here for instructions on how to set the clock...
http://www.fixya.com/support/p187738-jvc_kd_g200_cd_player/manual-17158/page-9
18helpful
4answers
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
JVC KD-G220 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Ekse
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
