Question about Activision Video Game Consoles & Games
Wireless receiver not working
The little black reciever that you plug into the console dosen't light up anymore. i just used it and put it away. when i went to use it again, nothing. guitar and game works fine. why has this happened,someone told me to change the settings on the console from browse to console, but i don't have this option in my menu. help!!! i have ps2 and the metallica guitar
Posted by lelgen760 on
4 Related Answers
Anonymous
  • 10 Answers
SOURCE: guitar hero 3 problem
you should replace batteries and try again
Posted on Jul 31, 2008
Anonymous
  • 97 Answers
SOURCE: Guitar Hero III for PS2 - Cordless guitar
check redoctane.com for a replacement receiver, i am not sure if you can buy another one but its worth a shot. good luck
Posted on Aug 07, 2008
Anonymous
  • 7 Answers
SOURCE: rock band wireless guitar problems for ps2
it MIGHT be something in the guitar thats not letting it work. just ask a person who knows what hes doing take it apart and find the problem
Posted on Jan 04, 2009
Anonymous
  • 10 Answers
SOURCE: guitar wont work
the guitar is the problem you need to replace it with another
Posted on Jan 06, 2009
I have a set of Azden wireless microphone, WMS-PRO. The sound is very low. I got a tip to open them up and adjust a tiny screw labeled VR101 (trans) and VR2 (rec) that adjust pick up. But somehow I messed...
The third screw was likely a frequency fine-tune adjustment. I would try having it turned on and transmitting, while carefully re-adjusting that third screw until it re-centered on the correct frequency.
On most wireless systems, sound level issues would only require making adjustmen to the reciever only, and if it's for stationary use, such as a PA system or mixing console, then better to leave it alone and boost the gain on the amp or console.
Considering the price of that particular model, if you don't need the reciever to be portable (such as for on-location vidiography), then I'd more strongly recomend spending only a little more for a more reputable, professional brand if you ever decide to upgrade or replace, like the "Sure SM-58" series that I now use.
Oct 14, 2013 | Garden
My online for ps3 doesnt work anymore. i dont know why it just suddenly stopped working and hasnt worked for a few weeks now everythings plugged in and nothings changed or anything.
refresh ur router or unplug it then disable your netlock or net filter... if that dosen,t help remove your router password and easy install your ps3
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
How do I get my Mad Catz wireless controller for ps2 to work? Not sure which buttons to press on controller to get it to work.
If the reciever is plugged into the console it should just work. There IS a power button on Mad Catz. Make sure it's turned on but other than that it should work. It doesn't need to be synced to the reciever. It was made already synced. Check the batteries. Make sure the reciever is plugged all the way in.
Nov 30, 2009 | Mad Catz NFL Controller for PlayStation 2
Xbox 360 wireless pc controller reciever not working??
My receiver died two days ago, i opened it up, and the Fuse was damaged, dont know how it could happen, not that much of current going thru that receiver, well the thing is all you have to do is get a solderer, and soldering iron, remove the fuse and solder a little cable so that you have a close circuit, The fuse is on the down side of the PCB (Printed Circuit Board), its named after F1
Jul 03, 2009 | Microsoft Xbox 360 Controller
Wireless guitar for guitar hero won't connect
Check cells put into the controller. Reaciever may not be properly inserted or switch button on reciever.
Jun 06, 2009 | Sony PlayStation 2 Slimline Console
Controller problem
The reciever is the part that plugs into the console where the wired controllers go.
You will not be able to use the wireless controller without this part as the console will not be able to pick up the signal without it.
Apr 23, 2009 | Video Game Consoles & Games
Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
Mar 11, 2009 | Microsoft Xbox 360 Wireless Controller
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Video Game Consoles & Games Logo
97 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
