I turned on my PC one day, and sidebar just decided not to go. I dont know why or how to fix the problem. I went to do a system restore, but noticed i had no system restore points set.....can anybody help me please???
Posted by annalouis579 on
  • Anonymous May 11, 2010
    You could try reinstalling windows. It helps if you have experience of installing xp or if someone is at hand who has the experience. If not, there are some pretty detailed instructions on how to go about. The best thing is to go an XP users book from your local library.
    A lot depends on the original installation.
    Some computers like those sold by Time come with a reinstallation. You would have to read those instructions carefully, but I have found the process straight forward.
    The approach to follow therefore depends on which type of installation your computer came.
    It is important to have backed up your data. If the data on the computer is important to save, you will have to approach the reinstalltion very carefully.
Lewis Fulkerson
    Scholar:
  • 69 Answers
Having a sidebar problem would indicate you're using Windows Vista, so I'm going to go from there. Microsoft has had a lot of problems with the sidebar feature, and has dropped it in Windows 7. I strongly recommend that you turn it off and leave it off. You can get things you need for your desktop without using the sidebar.
As far as the restore points go, you should have several set up automatically, but since you don't do the following:
Click on the start button, then find "Computer" (or My Computer) in the right column. RIGHT click on Computer, then left click on Properties. This brings up the System window. Select System Protection from the column on the left side of the window (Task List). Click the CREATE button near the bottom of this window to create a restore point.
Give the Restore Point a unique name of your choosing.
Of course this won't help you now, so I would shut off the Sidebar and try to live without it. Otherwise, go to the Control Panel, find the sidebar icon and click it. Set it to open the sidebar when you start Windows. You may need to reset your preferences to get it back to what you wanted.
If this doesn't work, you probably have some type of Malware or virus on your system. The best way to check for this is to go to the following web page: www.malwarebytes.org - and download the program using the blue button. Install it (click RUN) and update it, then let it run a scan (follow the instructions). Once it's done, restart your system and see if it's fixed.
Usually, restoring your system for a sidebar problem really isn't a useful or good way to resolve the issue. For one thing, on some systems, the sidebar seems to randomly decide not to work, and on others it seems to cause other system problems. I've seen very few Vista systems that did not improve with the sidebar feature shut off.
It's important with Vista to be very particular about keeping the Malware off the system, and keeping the registry clean. Using CCleaner.exe is a good way to do this. Clean the registry at least once a week, and do NOT defrag more than two times a year. Vista seems to not appreciate too much defragging. Keeping your system healthy and shutting off the sidebar are two of the best solutions for most Vista problems. Finally, I recommend you upgrade to Windows 7 as soon as possible. Even the RC-1 is better than Vista.
Posted on Oct 09, 2009
Windows 7 installation never-ending loop
andrew it can be a microsoft update.which was pulled back some days
ago.KB/2823324 i dont say it is,only it can be.
Apr 16, 2013 | Acer eMachines Black EL1352G-41w Desktop...
My computer deleted all of my Libraries stuff (Music, Pictures, Videos, etc etc...) i dont know what it did, one morning i logged on, and it went back to all the original settings of Windows 7, and i don't...
the one option is to restore your computer to the previous day if you formated and reinstalled windows this is not possible to restore click start click program accessories system tools click system restore it will ask you to if you want to restore computer to earlier time or you want to create a restore point click restore computer to earlier time click next you will see the calender in which some dates high ligtened click any highlightened date of previous day and click next it will restore the system to that day it will help you to recover the lost files
Nov 14, 2010 | Computers & Internet
8002F997 error for ps3 update 3.21
Haha...haha,
So naive a problem.... Try this:
you go to settings, system settings, go down and it will say restore playstatio
Apr 01, 2010 | Sony PlayStation® 3 (80GB) Console
My daughter has an Acer laptop running XP. The
Hi i'm Rain.
Follow the instructions below to resolve the issue.
  1. Click start.
  2. Click All Programs.
  3. Click Accessories.
  4. Click System Tools.
  5. Click System Restore.
Now Keep the default Settings { Restore my computer to an earlier state} and click next.
Now select a date that you know for sure is before the problem accured. Click next an allow the restore to correct the problem. The system will reboot after the restoration . Now a restoration complete notice will appear.
Click Next or Ok to continue to desktop. Your icons should all be back in place .
Nov 30, 2009 | Computers & Internet
Windows sidebar stopped working
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
Dear reader; I bought hunting unlimited 2008, its been playing fine, today I went to play it and I can't seem to get it playing
You may restore you system to a previous date. Choose the date when it was working fine. Just go back a day or 2.
Steps
Start>All Programs>Accessories>System Tools>System restore>Restore to Earlier date.
When you restore to a particular date. the softwares loaded after that particular date wont be there. So be careful and dont go too far back.
Hope this will help
Regards
Sammy
Aug 31, 2008 | Computers & Internet
Webroot spysweeper
it is better if you change your spyware software.
i think you have already understood why your pc is like that.
otherwise restore the system to previous restoring point.
Jul 25, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Computers & Internet Logo
64 people viewed this question
Ekse
Marvin
Marvin
