Check these codes. 506, 520, 525, 536, 564, 565, 566, 567, 568, 569, 573, 575, 610, 710, 712. If you wish to get more details and setup codes, check this link.
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately. Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com. A single signal (LED flashes and beeps once) response from the lock indicates valid entry. A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry. • If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad. Changing the Master Code (Code length: 1 to 10 digit code) Always perform this operation with the door open. 1. Enter: # - Existing Master Code - # 2. The set light will stay orange for ten (10) seconds. 3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears. If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3. Test the new code several times before closing the door: Enter: * - Code - # • The lock will indicate a valid code change with a single signal. • The lock will indicate an invalid code change with a double signal and the old code is still valid. Changing the Manager Code (Code length: 1 to 10 digit code) Always perform this operation with the door open. 1. Enter: # - Master Code or Manager Code - # 2. The set light will stay orange for ten (10) seconds. 3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears. If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3. Test the new code several times before closing the door: Enter: * - Code - # • The lock will indicate a valid code change with a single signal. • The lock will indicate an invalid code change with a double signal and the old code is still valid. Activate user codes (Code length: 1 to 10 digit code) Always perform this operation with the door open. 1. Enter: # - Master Code or Manager Code - # 2. The set light will stay orange for ten (10) seconds. 3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears. If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3. • The lock will indicate a valid code entry with a single signal. • The lock will indicate an invalid code entry with a double signal and the old code is still valid. Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5). Changing the user code Always perform this operation with the door open 1. Enter: # - User Code - # 2. The set light will stay orange for ten (10) seconds. 3. Enter: New User Code - # - New User Code - #, before the orange light disappears. If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3. Test the new code several times before closing the door: Enter: * - Code - # • The lock will indicate a valid code change with a single signal. • The lock will indicate an invalid code change with a double signal and the old code is still valid. The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3. Deleting user codesAlways perform this operation with the door open. 1. Enter: # - Master Code or Manager Code - # 2. The set light will stay orange for ten (10) seconds. 3. Enter: User ID Number (3-7) - * - # - # Programming your lock codes 2
paper jam , but you ned to open the upper cover then clean stel ruller which the head of ink cartdrige move in it when it copy then but graze and then clean the slot of unite waste ink yiu see it when the cartdrige stop move then put graze on it and try move it on you hand some times and see the move must be very easy thts all
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
after typing 3 times wrong code your phone is permanently locked and you must use service lile www.unlockbb5.eu price is around 20gbp if you interested please contact me at [email protected]
