1997 Ford F150 Regular Cab Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the torque specs for a ford 300 inline 6
I need the torque specs for a 1987 ford 300 inline 6 cyl flywheel and pressure plate
Jim DuBreck
Level 3:
  • Ford Master 578 Answers
  • Posted on Oct 10, 2009
Jim DuBreck
Ford Master
Level 3:
Answers
578
Questions
Helped
252808
Points
1695
Tighten all bolts to 10 Lbs, then 20 Lbs, then 35 Lbs.
That should be fine for the 6 cylinder flywheel.
Torque specs 03 kia spectra flywheel and clutch plate
Here are the torque specs for the flywheel and clutch plate on a 2003 Kia Spectra: Flywheel: 78 - 80 ft-lbs (106 - 112 Nm) Clutch plate: 19 - 21 ft-lbs (26 - 29 Nm) It is important to follow the torque specs carefully when installing the flywheel and clutch plate, as over-tightening or under-tightening can cause damage. Here are the steps on how to torque the flywheel and clutch plate on a 2003 Kia Spectra: Install the flywheel and clutch plate. Use a torque wrench to tighten the flywheel bolts to 78 - 80 ft-lbs (106 - 112 Nm). Use a torque wrench to tighten the clutch plate bolts to 19 - 21 ft-lbs (26 - 29 Nm). Reconnect the battery and start the engine. Check for leaks. If you are not comfortable tightening the flywheel and clutch plate yourself, you can take your Spectra to a qualified mechanic.
1997 Ford Super Duty 7.5 manual gearbox dually. I need torque specs for flywheel to crank torque specs, pressure plate, bell housing specs please?
For that many parts you need a repair manual. For single torque specs you can sometimes find them via Google using 'year make model (the part) torque spec'.
https://www.google.com/search?q=1997+Ford+Super+Duty+7.5+repair+manual
Need torque specs for the dual mass flywheel on a 2009 Nissan Versa 1.8l hatchback
I have been working on cars for over 40 years and ASE certified and have never used torque specs on a pressure plate or Torque convertor I will put a breaker bar and socket on the harmonic balancer bolt on the front of the engine resting it up against the frame you should also use blue Loctite on pressure plate bolts then tighten them up in a star pattern be sure to have alignment tool in in place so the clutch disc is aligned in the center pressure plate the specs for tightening bolts are PFT
2006 gmc canyon 2.8l manual transmission flywheel torque specs. And pressure plate torque specs.
Flywheel - 18 ft lb plus an additional 50 degrees
Clutch plate - 15 ft lb
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Torque spec's for the fly wheel
? looking the bolt tension specs for flywheel and clutch pressure plate for 4hf1 thank you
Torque Specification - National Truck Spares ' Parts
www.nationaltruckspares.com.au/Parts.aspx?ProductTypeID=8...
1073, 4BC2 tq, Isuzu, Torque Specification, KT26 TLD57 NKR57 NPR57 ... 1075, 4HF1Tq, Isuzu, Torque Specification, NKR66 NPR66, 92 - 03, 4HF1, 4334
Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
boxwrench.net/specs/chevy_sb.htm
Flywheel (Clutch). Thread Locker, 60 ft-lbs. Clutch Pressure Plate, Thread Locker, 35 ft-lbs. Centerbolt. (Harmonic Damper). Engine Oil, 60 ft-lbs. Bellhousin
1helpful
2answers
04 4.6 mustang, what are the torque specs for the flywheel to crank bolts, and the pressure plate to flywheel bolts?
Flywheel/Driveplate Bolts 59-64 ft. lbs.I hope this helps you,and merry x mas,And please dont forget to vote on this
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
