Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Unable to enter convergence menu
Unable to enter convergence sub-menu from the system menu.
Convergence is outa wack.
Posted by dv8r on
Edward
  • Toshiba Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TVUnable to enter convergence menu - 2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 08, 2010
My sansui rear projection tv's picture is concave with convergence problem also how can i fix it
The convergence can become unstable if you have a failing colour wheel if a dlp set. the same thing can happen if your lamps is beginning to fail the poor frequency of light from bulb disrupts picture. Convergence is usually done by entering service technician code into set through the remote and entering the engineering sub menu and if you don't know what your doing or have a colour pattern generator you could make things considerably worse .
1helpful
My tv looks like it is in 3-d. i went to set-up menu, convergence, the red is off and will not move over to line up. it was fine one minute then it was out of wack the next.
The tv 100% have convergence problems,it dead.The tv convergence board,require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
2answers
Cannot get the set to focus. Colors are blured
Sounds like a convergence misalignment, go into the tv menu and look for other adjustments sub menu and follow the on screen directions,this is a simple procedure but will take a little time to get it adjusted just right. Directions are also on pages 20 and 21 in your owners manual. Good luck!
My convergence is outa wack!!!
If you don't have experience with soldering, a board replacement solution would be best. You can damage the pads that the parts solder to which will cause you more headaches.
Convergence alignment problems with akai ph4298hd
After replacing ics did you ck for opened resistors low ohms 1.5ohms etc...You must get print out of How To Enter Service Menu for convergence it will tell you which numbers control which colors to move up and down to complete alinement for convergences. You must have your hand unit the one that came with set It has all the controls you need to be able to enter service menu!I will check to see if i have How to enter service menu.for this set.
Red convergence
I suspect you have a bad convergence ic bad the letters 0n the ics start with stk replace ic you will have a good shot that will fix it. you do need to be able to solder . be careful. there are 2 ics replace both .
mcm electronics for parts
thanks jay
Color convergence out on rc 52 inch projection tv
If it is way out, it is more that an adjustment. It takes a crosshatch generator to do the convergence.
Electrode
Convergence
convergence ic bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Apex convergence
Try resoldering the convergence chips.
Double lines
There is a manual convergence setting. Press Menu until you see the option of convergence. Save settings by pressing Power until you see Save Ok. You can exit the convergence screen by pressing the PIP button. 0 reloads the convergence. It will periodically go out of wack again.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
