Check your fuses. if they are good, check power at the fan. get yourself a voltmeter
It could be a series of problems first id try a fuse to see if its blown are not if the fuse is ok then id try playing with the resistor if nothing happens try tapping on the fan motor with a screwdriver or small hammer light taps your not hammering a nail;) if that dosent get it started then try a different motor.
Check for power at fan, but frist check all fuses. if fuses are good then check for power at fan if you have power at fan then fan is bad.hope this helps.
http://technoanswers.blogspot.in/2012/04/how-to-remove-fan-clutch-on-2005-gmc.html
This will help.
Thanks.
