Music Logo
Posted on Oct 08, 2009
The BOSS FDR-1 produces a popping sound when played
The BOSS FDR-1 pedal when using reverb produces a ''ping/popping'' sound when certain notes or chords are played. Gets gradually worse when the reverb is set high rather than low,
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Oct 08, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
20617
Points
75
This is a common problem with this pedal experienced by allot of people. My best advice would be to sell it and put the money toward a real Fender tube amp and some good pickups. If you're trying to go cheap check out some Line 6 modeling stuff.
Best sound for dsl15h and MT-2
To achieve a tone similar to Synyster Gates' A7X sound, you may want to start with the following settings:
Green channel:
  • Bass: 5-7
  • Mid: 2-4
  • Treble: 5-7
  • Presence: 5-7
  • Gain: 7-8
Red channel:
  • Bass: 3-5
  • Mid: 3-5
  • Treble: 5-7
  • Presence: 5-7
  • Gain: 8-10
When using the Boss MT-2 pedal, set the tone control to around 12 o'clock and the level to taste. This should give you a good starting point for a heavy metal tone.
It's important to note that these settings are just a starting point, and you may need to tweak them to suit your own personal taste, playing style and the room you're playing in.
Keep in mind that the MX112 cab will also affect the sound,so you may need to play with the eq settings on the head and the pedal to achieve the sound you are looking for.
Also, keep in mind that the sound of the DSL15H head with the MX112 cab will be different than the sound that Synyster Gates gets with his rig. However, the settings above should help you achieve a similar overall tone.
Jan 28, 2023 • Boss Music
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
So when I'm using this RV-5 reverb pedal, input A seems to be fuzzy and give out a faint B flat like it's not connecting but i still get sound through it. It also pops and crunches A LOT when you...
Open and look for broken solder at the jack... common occurence when people step on plugs or cables going into these. Also look for circuit board cracks around the connector and also around the power input connector.
1helpful
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
My boss me 25 pedal's sound isn't as clear and good as the demos' sound. My amp is a randall RT100 which is a valve amp and my guitar is an LTD with the custom pickups. so the problem is the setting i'm...
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
2helpful
How to set a sustainer in zoom g1xn?
There is not a sustainer as such - However you can use the Decay parameter in the reverb module.
  1. Set the Module Selector knob to Reverb
  2. Choose a reverb type from H = hall, r = Room, s= Spring, A = Arena, t = tiled Room (arena 1 - should do it quite well)
  3. Turn the module knob to decay And rotate the value knob until the number 30 shows
Apart from that you may get a bit more sustain from using different Drive modules - the distortion drives such as Ed will give a longer sustain than the clean accoustic drive sounds.
Using heavier gauge strings on your guitar will also give longer sustain but make it a harder to play fast.
How do plug your guitar into the boss rv3 which jacks
Plug your guitar into the input and a cord from one or both outputs to the inputs of whatever you are using. Meant to be run in stereo for best sound. Two guitar amps?
Where can i find parts for a rv-5? I need the rubber gasket for the "guide bush hole"
A good electronics store should have the part you need. I think its a rubber grommet that your looking for. They are round but become oblong looking once they're in place. Hope this helps.
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
