Question about Fantom Vacums FM760 Twister 500DX Bagless Upright Cyclonic Vacuum
SOURCE: fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Posted on Dec 06, 2007
SOURCE: Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Posted on Feb 03, 2008
SOURCE: Wiring Schematic
Hope this will help you. There is 4 different ways to hook it up depending on what you have,
Posted on Mar 21, 2008
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®?
Posted on Nov 30, 2008
Nov 22, 2011 | Fantom Vacums FM741 Twister Bagless...
Mar 04, 2011 | Fantom Vacums FM780 Twister 700LX Upright...
Sep 06, 2010 | Fantom Vacums FM741 Twister Bagless...
Aug 07, 2010 | Fantom Vacums FM741 Twister Bagless...
Jan 02, 2010 | Fantom Vacums FM741 Twister Bagless...
Jun 28, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Jun 16, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
May 22, 2008 | Fantom Vacums FM741 Twister Bagless...
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
