Question about GE JGRP20 Gas Single Oven
I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
Posted by jenn_lanclos on
steve
  • GE Master
  • 3,361 Answers
You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
Posted on Oct 08, 2009
Is the oven self cleaning and if so how does it work?
if its self cleanin it will say right on it "self cleaning"
self cleaning ovens do exactly that they clean themselves no harsh chemicals (oven cleaner foam) are needed to dissolve the baked on cooking goo that builds up inside ovens , although if one uses a foil liner in bottom then one might never need to self clean it , but some models cant use liners due to convection fans air flow getting in the way ,
self cleaning ovens have the ability to get very hot (500 degrees plus) no one should ever open a oven in cleaning cycle as this hi temp can spontaneously combust to ashes your hair/clothing never the less burn the hand that opened it severely(most lock the door for safety) all that needs done after cycle, is ashes need wiped out with damp towel next day after cleaning cycle is done and oven cooled off completely , im waiting on the day they make one that sweeps its self out into the dust bin ,(not yet )
Sep 26, 2015 | Ovens
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
Lost manual for self cleaning oven, do i put oven cleaner before turning on?
Harriette; Don't use oven cleaner on your "SELF" cleaning oven. You will just cause problems if you do. Let it do it's thing and when its done just wipe out the ashes with a damp cloth.
Dec 05, 2011 | Frigidaire Ovens
Is mr muscle safe to use in gas ovens
Yes you can use it in gas or electric ovens....if you gas oven has a standing pilot, you may want to shut that off while you are cleaning the oven...
heatman101
Feb 04, 2011 | Ovens
The inside of my self cleaning smooth top range
Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
Sep 07, 2009 | Ovens
I would like to clean inside my oven on the top
if you have a self clean oven, do not use an abrasive cleaner to clean
I would recommend running a self clean cycle, and anything left
"Mr. Clean Magic eraser" should take care of it.
it works miracles in ovens
May 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I start the clean cycle
The "S" in the model number stands for standard clean oven (vs. self clean), so unfortunately, you will have to use a can of Easy Off or similar oven cleaner.
May 07, 2009 | GE 24" Built-in Single Electric Wall Oven...
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
GE JGRP20 Gas Single Oven Logo
431 people viewed this question
Top GE Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
