Dishwashers Logo
Posted on Dec 02, 2017
Hi my Candy dishwasher model CDI 1012/2 is filling with water then after a few minutes if bleeps and the error code meaning according to the manual is "Longer inlet time. possible cause Faucets is not open" The tap is fully open and the dishwasher is now full of dirty water. Could you please suggest an alternative cause?
5 Related Answers
Anonymous
  • 209 Answers
  • Posted on Oct 07, 2007
SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Anonymous
  • 706 Answers
  • Posted on Oct 11, 2008
SOURCE: plumbed in new dishwasher wash
Hello lozjojo,
Based on your problem description, you either have no water pressure at the inlet valve or the inlet valve isn't operating and allowing water in. Prior to installation, did you make sure you removed ALL the packing material from everything? Is there any way tha you can check your supply lines for water? Also, some of the new flex water supply lines have built in anti leak 'shuttle valvles' inside them to prevent flooding if the line bursts.. Unfortunately, I don't know how you tied in the supply lines to the dishwasher itself.. If you used the anti-flood type supply lines.. that is another consideration to investogate.. If nothing I suggested resolves your problem.. please elaborate on the method you used to supply water to the system.. Good luck .. and hope I helped you...
Regards
Anonymous
  • 132 Answers
  • Posted on Jun 14, 2009
SOURCE: Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Anonymous
  • 332 Answers
  • Posted on Jun 23, 2009
SOURCE: Hi All, we have just
you do not have enough water pressure,, either change the water supply or check the pressure in your house should ba about 70lbs, to work the unit properly,, you could also increase the water supply from 3/8 to 1/2 inch up to the connection of the unit
Anonymous
  • 4 Answers
  • Posted on Oct 04, 2009
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Candy dishwasher LDT7797BM error codes EF
Ah, a DISHWASHER!!
Now... 'EF' as you wrote, or 'FE'?? FE is Fill Error. Low water pressure, blocked tap, Blocked strainer screens, faulty water inlet valve.
LG / Candy
https://www.google.com/search?q=Candy+dishwasher+LDT7797BM+error+codes+EF
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
2helpful
2answers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Candy cdi 1012 runs for approx 3 minutes goes to fault and does not make the spray arms move
I haven't got an answer to your problem, I just feel more comforted that someone else has the same fault as mine.
hope this helps
regards JL
Top Candy Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
