Question about GE Freezers
My GE upright freezer constantly beeps!
2 year old upright freezer; front electronic panel read out varies between temperature (2 degrees) and CE and beeps every 5 seconds. We have ''reset'' the alarm and unplugged/plugged in the freezer several times in an attempt to get the beeping to stop. The manual says ''operational error - call for service.'' Help!
Posted by youngetal on
David Emmel
    Sergeant:
  • 295 Answers
It sounds like this is a a non DIY issue. there is really not much you personally can do.
Contact an authorized servicer fir best results
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Dec 15, 2017
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: freezer problems
you could try a 3 in one hard start kit... comes with a copacitor to help start compressors with age and having trouble starting
Posted on Sep 11, 2007
Anonymous
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
Michael Anderson
  • 172 Answers
SOURCE: Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
SOURCE: The door of the freezer was left ajar. Alarm light is on and the inside temperature is now about 10 degrees. At what temperature will the red light go out or do I have to reset it in some manner? Than
Thanks for the update. Can we get a "problem solved" rating -- I believe there are icons at the bottom of the screen.
thanks..
Charlie
Posted on May 12, 2009
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Beeping coming from freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
My freezer will not quit beeping
try unplugging the unit and waiting 2-3 minutes to allow the electronic ontrol to reset. I am assuming that the temps are normal. peyton
Jan 27, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Hi dgh1,
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer cycling on and off rapidly
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
May 14, 2008 | Freezers
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
462 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
