2003 BMW 325 Logo
Posted on Oct 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2003 E46 and the CD changer will not eject the CDs. Is there a manual eject?
Anonymous
Level 3:
  • Master 510 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384437
Points
1812
Make sure cd changer is recognised on display on dash using mode on radio.This means it has power and correct connection.Next hold eject button on changer and insert credit card under cartridge,move left to right .This will locate micro switch and release cartridge.
1helpful
I CANT EJECT MY CD CHANGER ON MY 2000 E46 325I IT MAKES A NOISE BUT WONT EJECT, ALSO IT WONT PLAY ANY CD IN THE CHANGER, IS THERE A WAY OF MABY MANUALY EJECTING IT ? MANY THANKS, MITCH
You need to pull CD player, then remove lid (4 small screws) and you'll find CD lodged and can easily remove. Put lid back on, reinstall player and you're GOLDEN!
Cd changer in 2003 mercury mountaineer is stuck. What should I do? In the past the cd changer would make the sound like it is rotating the cds, but now it's is doing nothing, but telling me that there is...
If there is a small hole near to the eject button press on it using an office pin to reset but if not present while switching on slightly tap on the sides to see if the jammed cd comes off.
The fault with many changers getting jammed- most of them- is that some CD's warp off inside the slot and gets struck while the vehicle is moving with the track changing. Normally even with a good suspension the cd's can get off tracked.
So if there is no result open the cover and move the mtor manually assistingg the CD to come back to the cartridge slot.
Now check all the CD's and remove suspected ones.
If the changer does not work make sure that the loading motor flexible strip is connecting . check continuity,
Or else check board for any cracks or connection issues.
2answers
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
1helpful
Ford cd changer problems
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
12helpful
6 disc changer will not eject cds==
One common solution is to disconnect the negative battery cable for 10minutes. When you reconnect, the stereo should reset itself and allow you to eject your CD's . Best of luck!
Greg
4helpful
2answers
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
4helpful
2answers
7helpful
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
45helpful
18answers
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
