Question about Rotel Audio Players & Recorders
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4 volume on the preamp when one amp went dead. Inside the right channel keeps blowing both fuses when I power up?
Posted by pwakefield67 on
Franco Pinto
    Habit-Forming:
    New Friend:
  • 111 Answers
Hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Posted on Dec 21, 2017
2 Related Answers
Duncan
Mike Duncan
  • 219 Answers
SOURCE: Rotel RA 9808X Amplifier
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Posted on Jan 18, 2007
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Posted on Mar 12, 2010
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
No sound from one tweeter
Could be an open capacitor in the cross-over, unconnected wire to the tweeter (not likely) or a blown (open) voicecoil in the tweeter. Remove the tweeter and with a 9 volt battery (even run down but not dead will work) quickly touch it to the connections to the tweeter - it should pop and crackle. No static, the tweeter has sung it's last song.
Apr 08, 2011 | Acoustic Research AR 318PS Speaker
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Woofer not working on new bx8a speaker
Hi ermo
Your new speakers are BiAmped, and if a woofer is not working then it is probably a fault in the amp or connection for that woofer, or the the woofer itself has a problem. If they are brand new, I suggest you take it back to purchase point to get sorted out. There is nothing that you can do that will NOT void your warranty. If you do not have a warranty, then get back to me here and we can work through the problem. Cheers
regards
Graeme
May 23, 2008 | M-Audio Studiophile BX8a Speaker
Car audio
As long as the crossover keeps the frequency going to the tweeters within a safe range (I'd say about 500hz+, read the box or look it up by model number) they should be just fine. That is what the crossover is for.
Apr 01, 2008 | Car Audio & Video
My tweeters do not give sound
just run the tweeters to the front speaker channels on the radio
Mar 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
152 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
