OK, This should get you started on the problem. You need to remove the Fuse first to stop it running. Locate the fan switch and check that it is not permanently on (Short Circiut). If it is, Fit a new switch.
If not, then you need to locate the Fan Relay Switch and see if this is stuck on.
Thats assuming you do not have a short circiut in the wiring loom.
You can drive without the fan but not in slow traffic, you must have airflow across the radiator to avoid damaged. Do not allow the car to overheat.
