2001 Mercury Cougar Logo
Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 mercury cougar can't get car to start alarm light lit and steady what do I do
Anonymous
Level 2:
Scholar:
  • Expert 78 Answers
  • Posted on Oct 03, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
78
Questions
0
Helped
23359
Points
243
Sounds like your alarm is preventing the car from starting.
you can disconnect your negative battery cable, and wait about 10 minutes. put the key in the ignition and turn it to the ON position, but NOT to the START position. reconnet the battery cable CAREFULLY with the key ON, and the driver's side door OPEN. your alarm should "chirp" a few times, while reconnecting the battery. afterwards, try to start the car when the battery is tightly connected.
if the car still refuses to start, use the "panic" feature on your remote, to intentionally set off your alarm, and then turn it back off, to make sure it stops properly.
if this does not work, remove the fuse for your alarm, and try to start the car again without the fuse in place.....otherwise replace the fise and remove the pwoer connector from your alarm.
your actual alarm should be behind the trim plate, on the bottom side of your dash, above your gas and brake pedals....then try to start the car AGAIN....
if none of this works, then your alarm is defective and needs to be serviced be the installer, or manufacturer. also, calling the manufacturer will help too, as they have "reset and disable" features that can literally "bypass" your alarm.
2001 Mercury Cougar 2.5 litre V6. I replaced the fuel pump but car no longer starts immediately.
Question edited for clarity and add maker.
Question moved to model category.
What is the anti-theft light doing?
https://www.google.com/search?q=2001+cougar+2.5+reset+security
You say "doesn't start _immediately_". So it starts eventually?
How do I reprogram the car alarm system of a 2001 mercury cougar? the car alarm goes off randomly.
I once had a new car do the same thing. It was a short in the battery. The alarm system was thinking someone was tampering with the power supply.
2001 MERCURY COUGAR DOOR AJAR ALARM WONT QUIT BINGING EVERYTHINGS BEEN CLEANED AND WONT STOP PLEASE HELP
My 2001 Cougar control won't lock nor unlock the car and it just beeps rapidly when i press the controller, could it be the sensor on the door hinge? I noticed it's a little rubber boot. What could it be?
New battery installed in 2002 mercury cougar, and the alarm goes off and the left and right blinkers flash.
It sounds like you have an aftermarket alarm system that has malfunction. Contact the manufacturer of the alarm for the reset procedure.
2001 mercury cougar 2door coupe, how do I stop an unexpected alarm?
If it is an aftermarket alarm then you adjust the sensitivity it under the dash youll see a little square box turn to the right and you decrease sensitivity or left to increase lets say a feather fall on it and the alwrm goes off. Now if it is factory alarm they have the access for it and they reprogram the alarm sensitivity.
Secruity alarm light blinking car want start on a 1999 mercury cougar
hi this is marcus i have one doing the samething and i have it at the ford place and they say it is a part call cluster part it makes the car think someone is trying to take it and it want start the part is about 700
Replaced battery and engine light came on, how do i reset
its possible that you have ANTI-THEFT ALARM SYSTEM or the PASSIVE ANTI-THEFT SYSTE, to DISARM I suggets check the 2001 Mercury Cougar - Owners Manual (page and next).
Tell us news.
2answers
Instrument Cluster lights do not go on, emergency lights steady- Sable 2002
Has anyone figured this problem out? Our 2002 Sable just started this as well...instrument cluster lights out, turn/hazard lights on when the headlight switch is turned on. This has the auto on/off switch with fog lights. This is happening in the auto and manual on mode. Any solutions would be appreciated.<br />
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
