Front windows seat stearing don't work if i disconnect and reconnect battery then they work for 3 to 5 days then stop working agian.after 3 or 4 weeks whole system shut down including remote control.then i open door manually and disconnect and reconnect battery then every thing start working again in same routine. any idea what is causing this problem.
Battery Disconnect Window Reset Procedure: Roll window all the way down ( in first position), then roll window all the way up. When you reach the top, press and hold the switch down for 3-5 seconds. Roll window all the way down (again), press and hold the switch down for 3-5 seconds. The window should roll up and down normally. Repeat the same steps for ALL the window switches.
