Automatic renault clio MK1. 1.4.
my car wont start! turn key - nothing.doesnt even try to turn over. i think the fluid in the gearbox may be over heating but im no mechanic so im not sure! The car also revs really high and doesnt seem to have the power to push the car forward.
SOURCE: Renault Clio automatic 1.6 RXE 1999
remove the bulb then it cant bother you ,if it drives alright leave well alone or it will cost you a new ECU unit so just ignore it or a bit of black tape over bulb or remove the bulb
check transmission level with drive wheels chocked up ,handbrake on and engine running with reverse selected.and thats as much as you can do as this gearbox in common with all modern cars is all electric,and its a renault which means its encrypted software so no weekend mechanic tune up gizmo from the states will evan contemplate trying to read this properly ,just a load of mumbo jumbo .trust me its a renault , i know what these gizmo sellers promise about their wonder readers and such but on modern cars from 2007 they are useless as now all modern cars are encrypted and your famous renault started it.This is so that all work on a brand of cars can only be undertaken by the dealer and general garages can go and hang their overhauls up for good or turn their garages into car washes or a big mac outlet
SOURCE: location of crank sensor on renault megane 1.6, 2004
bit confused...the cranksensor will be on the gearbox housing the camsensor will be near the cams not the gearbox if the camsensor has packed up it wont start but if it packs up while driving the engine will run untill you stop it then it wont start,a cranksensor could cause the engine to stop at anytime if it fails..your problem could be the idle air control valve or a timing related issue..
SOURCE: Renault Clio Air Con Fan Problem - Wont turn off
Find Someone else,
Have Them Replace The Fan Selector Switch,
There Is Only 1 Fan In The System, Since You Can Select Between Defrost, Dash, Floor,
But Cannot Control Fan Speed/Shut-Off Fan.
I Would Replace The " Fan Selector Switch" Installed In Your Heater-A/C Controller Unit
Mounted In Your Dash.
Take Care God Bless
SOURCE: renault clio 1.2 extreme problems
you may have been put literally offtrack. Check the crank sensor (TDC) and make sure this is working fine. I recommend getting it checked at an autorised service centre.
SOURCE: Renault clio radio
You do not use the buttons.
You have to use the Steering Wheel remote Control
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [¬ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
