2007 Chevrolet Cobalt Coupe Logo
Posted on Oct 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What fuses are required for the 2007 Chevy Cobalt
What fuse is required for the 2007 Chevy Cobalt brake lights?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 215 Answers
  • Posted on Oct 04, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
215
Questions
0
Helped
73636
Points
547
Jeff , the type and amp fuse need for the brakes are listed on the fuse box cover, its is probably a 10, or 15 amp fuse
Melvin
St Louis
Low beam and brake light out on drivers side of 2007 Chevy Cobalt?
As far as low beam, did you check the bulb?
You have left and right low beam fuses, underhood fuse block. Not only check the fuse, check the fuse circuit for voltage.
2007 chevy cobalt
its underneath the hood right above the battery compartment.
Fuse box diagram for a 2007 chevy cobalt
You can find the fuse diagram for both the interior and exterior fuse boxes at https://automobilediagram.com/chevy-cobalt-2004-2010-fuse-box-diagram/ We hope this information helps!
19helpful
2answers
Reverse and interior lights out, chevy express van
Fuse block under the hood. Driver's side, under the brake master cylinder. Number 18. TCB#2. Replace the fuse.
There is an under-engineered ground in the reverse circuit. If you back up with the dome lights on, it could blow that fuse. There should be some extra fuses under the cover of the fuse block.
10helpful
3answers
Cruise control Fuse location 2008 chevy cobalt
check you brake lights. if a light goes out your cruise control wont work.
Have no dash lights and brake lights.
the first thing you should check are your fuses. it sounds like that might be the problem
2007 Cobalt brake lights not working
you have a bad left front wheel speed sensor. try putting a little die-electric grease in the connection
Chevy cobalt lt 2007
It sounds like there is something very major wrong with your ride. I think it would have something wrong with the fuse box or computer system.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
