Question about HP PSC 2410 All-In-One InkJet Printer
Scanner noise (HP PSC 2410)
The scanner of my printer is making a strange noise for a few minutes when I switch on the printer! After it stops I can not execute any function!
I already unplugged the power cable for a while before I try it again!
Thanks in advance for the help.
Regards
Posted by webdesigner2 on
5 Related Answers
Anonymous
  • 79 Answers
SOURCE: scanning with hp psc 2410 photosmart all in one
Hi flipflop8
intact it is the windows update which has messed up ...
do one thing install the software completely and do not open HP director.
then download the full feature software for a higher version photosmart printer .keep the printer connected and powered on
start the installation for the higher version priner .. when it prompts for installation type chose advanced type then chose custom install. in the next window put a check in the drivers, solution center & photo and imaging device. click next ,it ll prompt u to connect the device . check the box which says connect later and complete the installation.. in this process HP director ll be over written with hp solution center open that from desktop shortcut and scan
to download the software CLICK HERE
Posted on Jun 06, 2008
Anonymous
  • 221 Answers
SOURCE: hp psc 2410 photosmart all in one printer/fax/scanner/printer.
Simple, Just goto www.hp.com/ and Search for User Manual there.
Posted on Jul 03, 2008
Anonymous
SOURCE: HP PSC 2410 All-In-One InkJet printer default settings
Please can i obtain advice on how to reset my printer, as i am getting funny noises from it and nothing else.
Posted on Oct 14, 2008
kornho
Francisco Cortes
  • 781 Answers
SOURCE: hp psc 2410 Photosmart
1. try to use system restore and go back tgo a previous date where you know the printer and scanner were also working
2. try to unistall the printer by uninstalling the printer phisically and by unistalling the driver from device manager and by unistalling the program that came with your printer from add and remove programs. and then download an updated driver for your printer and operating system and software and then reinstall everything as directed in installation instructions : (install driver package/software, then connect the printer and test ) http://h10032.www1.hp.com/ctg/Manual/bpu70226.pdf
3. for detail troubleshooting on fax and scanning go to this webiste for troubleshooting options for your printer... check also the FAQ as you may have a problem for which there may be an entry there.
hope this helps!
Posted on Dec 10, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: HP PSC 2410 Printer
Below the support page for your printer , in there you will find drivers and manuals for your model:
HP PSC 2410 Photosmart All-in-One Printer
On Vista you do not need to download an additional driver, but you have to follow instructions below, as the driver is already included on Vista standard drivers:
HP Printers - Installing the Printer Driver Located in Windows Vista
After installing the Vista driver also download the software:
» HP Printing Diagnostic Utility
Posted on Feb 28, 2009
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Clicking noise and will not print.
Hi Folks
My 2410 had the same problem and is now 100% functional again
Here is the Solution:
Go to hp.com
at search look for exactly:
!psc 2410 how to clean the scanner"
the first hit is the right one.
There is a complete description, how to do.
The problem seems to be, that the scanner can't calibrate on the right optical marker (inner backsite of the scanner glas) and the motor still retries to move the scanner behind this marker what causes the noise.
Hope it willhelp you
regards,
Michael
May 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart all-in-one...cannot make scanner work
I have the same PSC 2410 and contacted HP the print software is included in Leopard 10.5 but the scan is not. They have "no" plans on producing software and went as far as to recommend  third party scanner software to make it work.
Apr 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
Will not find home position after switching on makes clicking noise screen 's got egg timmer showing after afew minutes it stops clicking but remains with egg timmer showing help?
The carraige is moved by a toothed rubber belt and plastic gears. Unplug the machine, open the front cover, and manually relocate the print carraige to the far right. Close the cover and plug machine back in. Hope this helps.
Feb 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
scanner replacement is needed as this cannot be repaired,the lower printer part is perfect just the scanner parts needs replacement.it is also costly to get replaced.
Sep 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
Jul 13, 2008 | HP PSC 2410 All-In-One InkJet Printer
Noise on my printer HP psc 2410
I have experienced this problem numerous times since owning theprinter, and usually a full reset (# and 9 on power-up) has resolvedit. Not this time, however! Following Guest's advice above, I visitedwww.fixyourownprinter.com and found the solution: cleaning the glass. Thank you, Guest!
Freddy
Nov 08, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
141 people viewed this question
Ekse
efs_perpends
efs_perpends
