Apple iPod touch Logo
Posted on Dec 07, 2017
My touchscreen won't respond when i touch it, whats wrong?
When i plugged the ipod touch onto the computer it says "charging is not supported with this accessory" when i put music on and unplugged it it still says the same thing and i am not able to operate the touch screen!!!
can anybody please help me! i just bought it yesterday too!
THANK YOU VERY MUCH!!!
James Thomas Culbertson
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 07, 2017
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1114
Points
9
Did u get water on it?
2 Related Answers
Anonymous
  • 86 Answers
  • Posted on Apr 29, 2009
SOURCE: won't charge on Bose SoundDock
You're not doing anything wrong. Newer iPods and the iPhone require accessories that were specifically designed for them. For example, the iPod interface in my car will not charge my iPhone, however, I can still play music through it.
The only solution is to: 1: Buy a SoundDock II or 2: Charge your ipod seperately.
Anonymous
  • 10 Answers
  • Posted on Jul 22, 2009
SOURCE: "Charging not supported by this accessory"
The iPod 2nd Gen changed how it charges and all those devices that once charged your older iPod, will no longer charge this one unless you get the adapter which is at the apple store and I have seen it at walmart for about $30. that device converts the power for you so it will charge. my adapter works perfectly.
tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 • Computers & Internet
I have an ipod that won't respond respond to touch or turn on past the very low battery stage. what do i do?
Connect the supplied USB cable to the IPod and plug it into the computer's USB port. The computer will then charge the IPod.
My ipod touch touchscreen has stopped working. ipod is fully charged and all buttons work but i cannot unlock. touchscreen is not responding
Try and press the top button and the home button at the same time for about 7 seconds.
Hopefully your Ipod closes down and you will see the Apple logo on your screen.
Just let it initialize and syncronize.
This will hopefully help. If not you might need go to your Apple retailer and leave it for repair.
Good luck
Just bought a ipod but dont know how to use it
The first thing to do would be to download itunes from http://www.apple.com/itunes/ and install it on your computer. Once installed plug in your ipod to using the supplied usb cable. You will be able to charge your ipod and update the software on your ipod. Once it is fully charged you can use itunes to transfer music onto it. As there are so many things you can do on your ipod you should download a manual from http://support.apple.com/manuals/
I just purchased an ipod, how do I set it up?
My ipod touch wont let me sync songs onto my ipod. im so confused
Uninstall itunes from your computer and re-install the same itunes version you had before. Make sure your ipod is fully charged and then plug it in and have a go at it.
Cheers old chap.
My touchscreen will NOT respond
Please follow this video to reset your iPod touch:
http://www.youtube.com/watch?v=Yzf-vUgM0Aw
Thank you
TechSaver
1helpful
My iPod touch isn't able to charge and doesn't show up in my computer and iTunes, what could be the problem I talked to the people at apple, but they said that nothing is wrong with the USB cable?
It probably needs a reset.
The apple support page is here>
http://www.apple.com/support/ipodtouch/
There are trouble shooting instructions on the page.
Ipod Touch 8gb problems
Hi K,
Ahhh, everything has suddenly become very clear :) All is well and there is nothing wrong with your ipod. Heres what you need to do.
  • First, install the very latest version of iTunes onto your PC or Mac - Download it from http://www.apple.com/itunes/download/
    Tip: Uncheck the two boxes and don't enter your email address
  • Once that's installed, start iTunes up and connect your iPod to the computer via a USB2 port (any on a laptop but not through a hub; on a PC tower use only one of the USB ports on the rear of the machine, ie, none of the ports on the front) - It's gonna need charging (That's what the Batt symbol is showing) so leave it for a good 2hrs.
  • While it's charging I'd recommend spending some time familiarizing yourself with the user guide - it explains alot of these symbols and more importantly how to get started with your new iPod. You can download the manual from here: http://support.apple.com/manuals/#ipodtouch
  • When it's good and charged then follow the onscreen instructions for the iPod on iTunes. You have to register the iPod first before you can use it. So once you've done this all will be well in the world for you. See page 5 and 6 of the manual.
All the best
Sean
PiDigital
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
