Question about Maytag Refrigerators
SOURCE: KSCS25TNSS Ice maker does not make ice
what position is the icemaker rake (teeth) in. normal position when not in harvest is at 2:00 if in anyother position its possible you have a bad motor module and gear. really nothing to do witht he filter at all.
if the module cks ok, look at the fill tube, ( black hose coming out of ceiling of freezer above icemaker) check to see if its frozen up. if so use a hair dryer and warm the tube up. these are the 2 most common issues i see.
good luck
Posted on Dec 19, 2007
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
SOURCE: MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Posted on Sep 15, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
SOURCE: Kitchenaid ice maker water flow will not activate
You can post your the problem at my site by clicking the link below. Then click on free diagnosis, enter model number and the details and it may take a couple days to get the answer, but free. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 21, 2009
Apr 10, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Jun 05, 2011 | Refrigerators
Aug 28, 2009 | Maytag Refrigerators
Aug 11, 2009 | Maytag 25.6 Cu. Ft. Side-by-Side...
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Jun 05, 2008 | Maytag MZD2766GES Side by Side...
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Dec 04, 2007 | Maytag MFI2568AE Side by Side French Door...
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
55 people viewed this question
