Question about ASUS Eee PC 4G Surf
I have a Asus eee pc 4g surf and it does not boot it neither show the BIOS post or show any hard drive led activity just a small blink when i push the power button. It seem to have a fully charged battery and the ac is working fine. It t=do the same thing with only battery or only ac and with both.
Posted by nbigio on
Larry Ng
  • ASUS Master
  • 5,978 Answers
No model EEE stated, it has a model number,
the screen is dead. if AC only fails.
or AC pack is bad. a $15 part to buy.
looks old to me, if older than 2010 all laptops have now bad, CCFL black lamps.
use a flash light after power on, if you see data there now that is a bad back lamps dead. most are this old, 9 years old.
Posted on Sep 16, 2019
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: Asus eee pc 4g bios password
You don't need to access bios to change boot drive just hit escape key a couple of times when you power on and it will give you options for which drive to boot from.
Posted on Jun 08, 2009
yboyandrei
Francis Mark Arango
  • 828 Answers
SOURCE: ASUS EEE PC 4G Password recovery!
its all technician consultation and for me remove the CR2032 battery inside the laptop to reset the biois inside... or press F8 to go safe mode and remove the previous password to enter at administrator...
Posted on Jun 16, 2009
dougmpage
  • 86 Answers
SOURCE: how to reset asus eee pc 4g surf to factory
Run the recovery software in the programs menu and fallow the prompts.
Posted on Jan 28, 2010
Anonymous
  • 28 Answers
SOURCE: My asus Eee pc 4g 701 will not connect wireless
yes! when it comes to wireless networking just make sure that your connection setting are correct just match the settings from your other laptops and do the same to the one you have probles if the persist just do a diognistic check for problems if that doesnt works just hit me back on my link ok!
Posted on Mar 26, 2010
Anonymous
  • 107 Answers
SOURCE: asus eee pc 4g wont connect to internet with
Can you connect through a "wired" connection? Is your router connected to the Internet? If you're using wireless encryption, have you told your netbook what that encryption key is?
Posted on Apr 29, 2010
Cant start after BIOS update
It sounds like the boot sector on the hard drive and a bypass of the Bios. Pull the hard drive and try to set the BIOs. See if that works for you.
Feb 26, 2014 | ASUS Eee PC 1215NPU17BK Netbook
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
Will not boot up
Even when it is being charged? And is the actual computer not turning on or is it turning on and the screen is showing no picture. two different problems.
Jun 30, 2011 | ASUS Eee 4G Notebook
My notebook hardisk is too small (8GB, ASUS) can I upgrade my Hardisk?
Yes you can BUT the maximum size you can update the hard drive depends upon the BIOS.
Alternative you can use an external USB hard drive to store your data and this is not restricted by the BIOS.
Jun 26, 2011 | ASUS Eee 4G Notebook
My name is Henry. I have a eee pc 1001p. I recently removed my batt. during a update and lost some of my bios settings. When I turn on my notebook i get to the boot screen and it says reboot and select...
Go to your BIOS by pressing the delete key as your computer boots up.
Find boot disk priority and set first boot device to your hard drive.
I suggest you unplug any flash drives as you boot the laptop.
Apr 27, 2011 | ASUS Eee PC 2G Surf Notebook
Hi, my asus eee 4g will not switch on. The power light and battery light are there, but no hard drive light. I have tried their troubleshooting advice, but no idea what could be wrong with it.
does your bios show at all if so its your hard drive replace it by buying a new one if not its your processer chip,if your a doing yourselfer go to youtube there are techs who like showing off there work you can buy parts from ebay if your under warranty take it back to the store where you bought it..
Apr 14, 2011 | ASUS Eee 4G Notebook
How to recover linux for EEE PC 4G
Simple, You need to get a USB - DVD Dongle, & your backup DVD that came with your unit. Inset the DVD, and boot of it, you need to access the BIOS and set the drive boot Up options, to boot from external USB connected, DVD, it MUST be all plugged in to show this. Then save settings and reboot. Follow instructions & then it will simply perform a complete restore. Now if you can't or don't want to use a USB-DVD, then you will have to make a Bootable USB Key, transfer the contents of the DVD to it and set to boot from that and do so, and install that way. There are a number of tutorial showing you how to do this.
look below...
http://eeepc-albkwan.blogspot.com/2009/06/create-asus-eeepc-system-recovery-usb.html
Feb 18, 2010 | ASUS Eee 4G Notebook
Asus Eee PC 2G Surf netbook fails to boot into OS
 Unfortunately Xandros is a paid (yes, you have read correctly , PAID) Linux distro. You will have to pay to get a Live-USB to reinstall.
Instead you should go here
http://www.pclinuxos.com/forum/index.php/topic,46097.0.html
  and follow the instructions to create your own PCLinuxOS (the one i use) Live-USB. You will need another pc for that. After booting from it all you're gonna have to do is to click on the Install icon on the desktop.
Dec 01, 2009 | ASUS Eee PC 2G Surf Notebook
How to reformat asus eee pc
Normally laptops come with a restore disk(s). Simply put the disk in the drive, restart the pc and boot the pc to the disk.
If it won't say (boot to disk) automatically, simply press F2 when you turn on the computer till the BIOS loads up. Then change the boot order to CD drive first.
Once it boots to the cd the process will run automatically.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | ASUS Eee 4G Notebook
Jun 08, 2009 | ASUS Eee 4G Notebook
ASUS Eee PC 4G Surf Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
