Saw similar problems.....replacing it is not the solution...finding a way to reboot it is. The fuse box is under the front hood. Problem is, on a v6 model, there is no fuse for the radio. Pulled some out, but nothing kills the radio. I saw on another site that if you reboot the CD player, by pulling fuse, it will eject CD. Could not find it today.
Disconnect the fuse for the radio. This is cause the radio to reboot. You do not need to mess with the battery. After replacing the fuse, or removing, it, and putting it back in, you can proceed to try to remove the CD. I used a pair of tweezers.I actually jammed two CDs into the player. Hope this helps.
The fuse for the radio is in the car.Check the owners manual for location.Try inserting another Cd and see if the one inside ejects.Forthemore if tou want to power off the CD player and can't locate the fuse box disconnect the battery and reconnect it
You need to remove the player from the vehicle and send it in for repair. If you check the internet under GM radio repair all kinds of repair centers will come up. Make sure to ask for you CD back once the unit is repaired and sent back.
Heres the method I have been using since CD's came out...
Gently slide another CD into the slot, keep hold of it! dont let it slide all the way in.
Once its about halfway in, GENTLY push down on it as you pul it back out.
The stuck CD should come sliding right out with it.
If power still to CD Player & Radio, the disc may just be stuck into unit. If it won't eject, after many tries, you need to get unit seen to by In Car Installer / Repair. If no power to unit, try fuse box,
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Figure out what fuse controls the CD player and, with no key in the ignition, pull the fuse out for a minute (or more - I've seen TSBs that say leave the fuse out for 10 minutes), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio presets and other settings. Make sure you have any codes for your radio that may be required since disconnecting the battery cables can cause the radio to quit working too. This fuse trick seems to have the greatest chance of success overall. Check your owner's manual - you may have more than one fuse that controls the CD and/or the radio and you may need to remove all the related fuses. (There's a "risky" variation of this tip described in the Multiple (6-disk, etc.) Systems section of the guide for attempting to fix a CD changer)
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Some players, especially aftermarket ones, use a CD cartridge or magazine. Tapping on the cartridge while pressing the eject button sometimes ejects stuck discs. CarSpace member Alwaysfords2 has been able to remove stuck CD magazines by using a piece of shim stock or a hack saw blade and going alongside one of the long sides of the magazine to hit the release. You can rock the magazine a little bit in the slot to see the mechanism and it should be easy to release - sort of like using the little pin hole on a CD drive, the magazine pops up as soon as it is freed.
Remove the faceplace from your player (be gentle; something like a butter knife often works without damaging the bezel or breaking tabs). Then look for a tiny, usually recessed little button that you can press. You may need that unbent paperclip to reach the button.
Find a coaster in your junk drawer - by coaster, I mean an old CD that doesn't work. Or use a blank one if that's all you have. Insert the coaster about an inch into the slot (yes, on top of the stuck CD). Then turn the ignition on and hold the eject button and wiggle the CD around. Don't be hamfisted - you're just trying to give the player some traction to help it eject the stuck one. If this fails, then try slipping the edge of the coaster (or something even thinner) under the stuck CD and pry it up while pressing the eject button. Again, be gentle - you don't want to ruin the player when a pro may be able to remove the unit and free the disc for $20 or so.
Find a Popsicle stick or something thin but rigid and tear off a few inches of Scotch Tape from that roll you keep in your junk drawer (next to all those ruined CDs you intend to make Christmas ornaments out of some day). Put the tape on the top of the stuck CD using the thin stick to help attach the tape firmly to the disk. Like the hint above, the idea is to lift the CD enough to enable the player to eject it.
At least one CarSpace member had success releasing a stuck CD by, ahem, banging on top of the dashboard!
Foreign objects stuck into the player, or CDs that miss the slot entirely yet wind up inside the unit usually require pulling the CD player to remove the disc.
If all else fails and the repair is expensive, you may want to upgrade to an aftermarket unit.
