SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set
BEARING to “MAG” (magnetic). This will cause the unit to display course /
bearing information in relation to the Magnetic North and match magnetic
compass readings. It is not the same as True North! One has to be careful with
this setting. There are a number of areas where the earth's magnetic field is
locally disturbed, sometimes very significantly. Your GPS may not account for
it.
again, under “UNITS” I set “METRIC”.
SOURCE: rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
SOURCE: I just bought a boat with a Raymarine C80 chart
Your problem is the 4GB card. The Raymarine C-Series have a problem with their compatability tool and larger CF cards. You should use a card no bigger than 256mb.
The card probably worked in the store because the newer models accept larger cards.
Get an older card from ebay etc and copy your 4gb files onto it and try again. There is more info here: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1042&p_created=1089743435&p_sid=Y9eWB6ek&p_accessibility=0&p_redirect=&p_lva=1042&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjYsMjYmcF9wcm9kcz0zNiwzNTIsNDEmcF9jYXRzPTAmcF9wdj0zLjQxJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1zaXplIGNhcmQ*&p_li=&p_topview=1
Hope that helps you out.
