Cars & Trucks Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trunk does not open with button inside car. Does open with key remote. Is there a bad fuse somewhere and if so which one?
Anonymous
Level 3:
President:
  • Master 333 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
President:
Answers
333
Questions
0
Helped
339573
Points
1660
Your Valet cancel switch is set.
Open your glovebox and you will see a pushbutton on the the left side, if memory serves. When this button is set, the power button will be disabled, but the key fob button will still work.
This is for when you Valet your car, you push the cancel button in the glovebox, lock the glovebox, then give the Valet your Valet key, which will not open the trunk or the glovebox. Voila, no Valet rummaging through your trunk :)
Often full gloveboxes will be the cause of the button getting pushed accidentally.
  • Anonymous Feb 01, 2013
    YOU ARE ABSOLUTELY RIGHT, THANK YOU
  • Kent Durden
    Kent Durden Aug 25, 2021
    Yep, that's it! Thanks
sianap96
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2012
sianap96
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6826
Points
Maybe previously someone in your car has pushed the knob button inside of your glove box by accident that has disabled your trunk button, therefore Open your glove box, and you will see the knob button in the left side of the glove box, press in the knob button in order to activate the trunk button underneath the dashboard.
3answers
2009 vw cc trunk will not open from remote or from inside latch Trunk dont have key , only open by remote or inside latch , i try both way still can not open ,
check the fuse panel.... owners manual should list which fuse number is the trunk release. If fuse is blown, a new fuse may allow release of trunk. If latch release is bad or shorted out... the fuse may blow immediately.
Is there a release trunk button inside the car?
New Member - Trunk release question - Nissan Forum ' Nissan Forums
forums.nicoclub.com/new-member-trunk-release-question-t320939.html
Mar 12, 2008 - I had a question regarding installing a trunk release. Since there is noneinside the car, a key is necessary to open the trunk. ... Hit the unlock button on the key fob twice (to unlock all the doors) and as EV says, walk over and press ... So thereis no way to open ther versa HATCH without the the key remote? trunk release inside the rogue?
Apr 18, 2009
I found the Trunk Button!!!
Sep 13, 2008
Anyone got Trunk release button on his remote ?
Aug 22, 2008
How do you open the hatch from inside?
Sep 13, 2007
More results from forums.nicoclub.com
2015 NISSAN Versa Sedan - Trunk Release - YouTube
? 0:37
https://www.youtube.com/watch?v=cE1SOFs_Tc4
May 5, 2014 - Uploaded by Nissan USA
2015 NISSAN Versa Sedan - Trunk Release. Nissan USA ...From inside the vehicle, pull up on the open lever. ? Unlock the trunk using the key. ... Press and hold the trunk button on the Intelligent Key.
The remote will not open trunk or doors and can not open the trunk from the inside of car
Remote could have a bad battery. You could have a blown fuse. Does the door unlock switch unlock doors? Can you hear the trunk solenoid when you push the inside unlock button? If not, and no blown fuse, could be a bad trunk solenoid. Could also be a bad remote entry module. Have someone check for computer error codes that might point to trouble - Stores like AutoZone will check your computer for codes for free.
The trunk release buttons on my 1995 Olds 88 starts the car but does not open the trunk!
Seems to me the auto start and your factory key fob have the same freq. if it is a factory remote start there is something crossed somewhere. You should be able to find a disconnect switch for your remote start somewhere( in fuse box area or underneath the dash) once found follow the wire to the remote start receiver. Visually check wires and try and get a make and model number of the remote starter. Google the wiring diagram for that type of RS.
2helpful
1994 buick lesabre trunk lock-how can I open the trunk without using a key. the key doesn't work although it open the doors to the car. is there a release button somewhere? we do not have the r
If it has the electric trunk release, the button could be in the glove box.
Otherwise you may have to remove the back seat to gain entry to the trunk.
Trunk release will not work in 1999 clk 430
Try checking to see if it has released buttons on the back top passanger seats.
28helpful
9answers
Chevy Malibu Trunk Problem
i have a 2005 chevy malibu and i close the trunk with the keys inside and the little button on the door is stock but the car is open is and other way to open the trunk from inside of the car?
6helpful
2answers
I have an 06 impala and the TRUNK WON'T OPEN. It
you have a fuse for it ,check the fuse box ,it might not say trunk on fuse panel, you might need to pull those fuses out one by one checking each one to see if blown, if the center between the two sides are broke the fuse is blown, hope this helps you, thanks robert b.
5helpful
2answers
2000 Jaguar SK8 Cant open trunk...batteries dead.
you can charge the battery from the engine compartment. check your owners manual that is the correct place to jump and to charge the battery.
3answers
Keys inside the trunk
Use the trunk open button in the clove box.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
