Olympus Camedia C-350 Digital Camera Logo
Tam Shields Posted on Sep 23, 2009
My card is full when i switch my olympus 350 on i cant page left or right to chose pictures to erase can get menu screen but cant go any further
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Sep 23, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6627
Points
36
Since your memory card is full, sometimes cameras stop working. try to use your card reader have it erase using your pc.
1helpful
2answers
How can I get my camera to delete photos see below? How can I get back to the main menu on it?
Have you tried replacing the card with a blank one, so there is space for the camera to move images to ?
Memory card full empty
first you should save the pictures to a computer. After you delete them they are gone forever.
But the view menu, you just press the menu button. In the most left tab, the third line is a bin. goto that line and press the arrow to the right. Then you can chose what you want to delete. Only one picture, pictures with a certain date, a folder or even all pictures.
it is in the English manual on page 101 and 102
1helpful
Olympus C-350 zoom indicates that card is full. Deleting files or changing card has no effect. Can you help?
One good reason for this problem is that you have been constantly deleting pictures from your memory card. To bring this back on line to working condition and restore the total speed and operation abilities of your camera you need to Format the memory card. First transfer all important files to your computer before formatting the memory card I'm including a diagram of instructions of how to do this. It's actually a screen shot of page 32 of your owners manual.
Formatting your memory card
Have a Happy New year
1helpful
2answers
How do I delete pictures from my memory card.. the camera says card is full?
A quick way to multi delete the pictures (providing you have backed them up first), is to use the camera's menu to format the card.
Formatting the card will completely delete all the images and get the card ready for use again.
Regards.
WRITE PROTECT
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
1helpful
It says picture error for every picture and cannot delete photos individually. One minute it said card full then every photo said picture error and switched itself off. Its not a happy camera
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error messages and the card can be used again.
6helpful
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
2helpful
When i turn my digital camera on with the memory card in it (XD M256mb) it says the card is full. I go to erase photos and it says there are no photos to erase. If i take the memory card out, i can take 15...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Deleting all photos
It's on <a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/page-91">page 91</a> of the
<a href="http://www.fixya.com/support/p220497-olympus_camedia_c_350_d_560_digital/manual-2351/">User Manual</a>
In the playback mode (ie shutter closed and press "quick view") press "OK" (the centre button!)
select MODE MENU (right),
CARD (down twice),
CARD SETUP (right twice),
"ALL ERASE" should be highlighted, (up/down will toggle between "ALL ERASE" and "FORMAT"), with "ALL ERASE" highlighted press "OK",
press up to select "YES", then hit "OK".
That's it you are done.
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 • Cameras
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
