Question about Hobart D300-6036 Mixer
Where to buy dough mixer parts please many thans.
Posted by amirsalimb on
Anonymous
    New Friend:
  • 110 Answers
The best bet is any hobart office in your area,i have seen many mixer damaged because of non-hobart parts installed in them
Posted on Jan 09, 2010
KitchenAid stand mixer KSM50PWH. Was kneading dough with dough hook attachment and it quit turning. Motor works fine but the part that's supposed to go round and round doesn't. Can I fix this?
The Nylon Worm Gear has stripped. This is designed into the part so if the Mixer gets overloaded, it won't burn out the motor. Which is odd if you have the reset switch like I do.
Part# 4162897
You can buy it online at Kitchenaid.com
6helpful
2answers
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
Which kenwood mixer to buy?
Hi. Congratulations for researching mixers. I wish I had before I bought my Kitchenaid HD Pro. All mixer manufacturers over-rate their products. Goto www.consumeraffairs.com and do a search for each mixer you are considering. Most mixer failures are caused by mixing heavy cookie or bread doughs. Although manufacturers claim that their mixers can easily handle these doughs...They cannot! My Kitchenaid self-destructed after 30 batches of bread dough. "For the way it's made"! Indeed! I solved my problem by buying a Hobart N50 mixer. It's a 5qt. and handles anything I throw into the bowl. I bought mine used, and refurbished it myself. New these units cost $2,035.00 USD.
If this solution has assisted you, please rate it. Good luck! ricardok45.
1helpful
2answers
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
1helpful
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Hobart D300-6036 Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
