The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at: http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it. LOCATION:The fuser cover is located in the back - its covered by the panel in the back called the "back cover" aka "back output tray cover". 2-step fix: (A) open the back cover - on the back of the printer. HOW: it flips down (B) open the fuser cover and remove paper jam How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover. (it also flips down to open). Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer. 2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer. 3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF. 2. Open the front cover. 3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover: 4. Reseat both cartridges in the printer and check for the error. 5. If the error still displays, then remove the color print cartridge. 6. Close the cover. 7. If there is no error indicated by flashing lights, the color cartridge has short-circuited. 8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9. 9. Remove the black print cartridge and reinsert the color cartridge. 10. If there is no error indicated by flashing lights, the black cartridge has short-circuited. 11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Some how, the sensor that reads when the cover is closed is not reacting like it should.
I assume that you have pulled the cover back up and then back down several times? The status then still indicates that th "cover open" and does not change?
We need to figure out why your sensor is not reading correct. It is located on the right rear when looking with the cover open.
