Do you mean your Epson Printer Printing blank pages? The Epson printer printing blank pages due to wrong paper size, outdated printer driver, Empty ink cartridge, dirty print head, improperly installed ink cartridge, and more.
Follow the steps to fix the Epson printer printing blank page issue:
·Restart the printer ·Fill the empty ink cartridge and reinstall the new ink cartridge ·Update printer drivers. If you have done all the above steps but still the printer printing blank pages.
Access your printer folder and run the printer utilities such as the printer head cleaning and alignment. After running all the utilities execute a test print page to see if the printer is functioning properly.
I know you've cleaned the printheads, but try this method:
(1) Open the printer (2) Remove the color ink cartridges from the print head. (3) Use cotton swabs dipped in hot water to thoroughly clean the print head. (4) Repeat this until there is no ink residue coming off on the cotton swab. (5) Once finished, allow to dry and replace the cartridges (6) Try to print something now
If that does not work then the print head(s) may need to be replaced.
did you remove the tape seal over the ink port of the new cartridge? are you getting any error messages? did you aline the printer in the printer tools? just some things to check
clean also the tab circuit to the printer maybe it suffered loss connection.. ________________________________________________ unplug and plug your printer...and try to wipe the cartridge on a wet cloth ..to determine that there is a ink going out on it...
Normal
0
Normal
0
Driver could be corrupt. Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Take the cartridge out and put it back in then try to print, if it is still the same try cleaning the print heads>control panel>right click on c66 and go to printing
