Question about RTO 50cc Moped Scooter
I have a piaggio zip 50 that cuts out when i rev it half way it has been sittin there for 2 years and i think my carbureta needs cleaning but i dont no how to take it apart i need a diagram
Posted by ryan_jerrom on
Anonymous
    New Friend:
Can anyone help me? when i turn on my piaggio nrg its fine but then the revs start going up by themselfes and when i pull the throttle back it just cuts out. i would be greatful if someone told what was wrong with it thanks
Posted on Nov 07, 2010
What type of bulb do I need for a Piaggio Zip 50 tail light?
They have seperate stop light bulbs to the tail light which is the uncommon.I think the stop bulbs are 12v 4 watt wedge fit sidelight bulbs,they use them in cars too as sidelight bulbs.the tail light one is a 12v 10 watt bayonet type.
Mar 06, 2015 | 2010 Piaggio Zip 50
Where does my 2 stroke oil Go in my piaggio Zip 50cc 2007
There should be a tank, usually under the seat or behind the rear side panels. Just fill the 2-stroke tank and don't worry about the mixing, the engine does it on it's own.
Feb 19, 2012 | 2007 Piaggio Zip 50
Took out air filter on piaggio zip sp 50cc forgot how it goes back in can u help thx u expert or experts p.s they dont show up on select motorcycles no vespa or piaggio categories any pic u can send ov how...
recently my piaggio zip sp has been loosing power wen under load going up hill and sumtimes when on full throtle it seems like the fuel is serging instead of feeding through smoothly anyone know wat could be wrong
Mar 14, 2009 | 1977 Moto Guzzi V 50 I
I have a three year old Piaggio 50cc Zip scooter. It starts first time and will run perfectly well up to half throttle. after this it loses power especially uphill, as though it is running out of fuel....
I have had the same problem with my stepsons zip 50 and have done all the usual checks. The solution is from a piaggio technition. Take off the air cleaner and housing, start the scooter and bring it to the point where the engine dies. At this point spray easy start or a gasoline spray direct down the carb intake. If the revs pick up, you have a lack of crank case compression and the most likely reason is worn oil seals on the crankshaft. It sounds odd but the worn seals cause all kinds of strange problems.
Thats 2 stokes for you. Hope it helps, good luck
Mar 03, 2009 | 2004 Yumbo Dakar 200
RTO 50cc Moped Scooter Logo
1,975 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
