Question about Car Audio & Video
Subs not working.
My sub turns on just fine, connections are fine. when i play music my sub has constant static going through it, thats all you hear. i have the stock bose speakers, kenwood headunit, power acoustic amp, rockford fosgate sub.
Posted by rjamesshafto on
Anonymous
  • 102 Answers
Blown sub if it sounds liek a cracking, with sub off, gently press the sub in, if you hear noise, its dead
Posted on Sep 23, 2009
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
I have a cerwin vega ve 28s sub and noticed static sound coming out even when no music was playing. The next day sub went into standby in the middle of a song. If I turn it off for a couple hours it works...
First, disconnect it and let it run with no input. Problem here is that it probably has an auto-turnoff and will shut off. My bet is that either your connection wiring is faulty and/or your amp is sending down either RF or DC signals. I would get it close to the amp with another connection cable and check... Good Luck !
Aug 12, 2014 | Audio Players & Recorders
I own a onkyo skw 980 subwoofer and it just quit. I have only had the system for a month or so. I was listening to music, not loud and the bass (sub) just stopped. No crack, pop, or blown speaker. The...
How are you sourcing the program material to the sub? This TX-V940 receiver doesn't have specific sub support.
=== Just the same...
You need to first determine which is at fault - the sub or the receiver.
Connect the Sub Input to Tape Rec on the receiver (but DO NOT select Tape) and see if the sub reacts to your playing FM, for instance. If it works you need to go back to the receiver and the unknown method you're feeding the sub.
You could also test the sub with a CD player output but use a recording that starts low because you won't have volume control.
Dec 24, 2010 | Onkyo TX-V940 Receiver
Static when playing music and speakers pop
try to clean the volume control with contact cleaners
May 05, 2010 | RCA RT2760 System
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Sub doesnt put out a sound
go into your sound properties and make sure your sub is turned on or not muted there should be a seperate one for sub just like you have one for speakers
May 26, 2009 | KEF Audio KHT 1005 System
Crackling coming from Velodyne DD-10 subwoofer
One of 2 things is going on.
First, the servo mounted in the driver may be going bad or is picking up some noise.
Second, Something in the amp section is going bad, hard to pinpoint the exact problem.
you say that it plays, so I tend to think it is the driver mounted servo unit.
If it is within the warranty time, take the unit back to the retailer you purchased it from, if not contact Velodyne for repair.
Mar 18, 2009 | Velodyne HGS-10 Subwoofer
Car Audio & Video Logo
157 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
