Question about MPS Multimedia QuickStudy Chemistry for PC
In a 1.5% lidocaine solution, how many grams of lidocaine would be present in 10ml?
Posted by mosespthomas on
  • dennis bullard May 11, 2010
    as a nursing student or whatever you are attempting to study you should consult your procedure manual or MIMS We are not permitted to assist you in cheating your way through medicine. YOU must learn this to be a successful professional. Thye formula is in the chemistry book
DubbleA
    Scholar:
  • 32 Answers
Hello, I can help you if you include more data in your question.
As an organic compound, lidocaine is insoluble in water, so I am assuming that either some combination of water and alcohol (ethanol), or a pure organic solvent like ethanol or diethyl ether is being used.
If lidocaine were soluble in water (which it's not), you would have been able to solve your problem as indicated below. Maybe you would be able to modify the indicated solution by taking into consideration the density of the organic solvent.
Percentage (%) by mass is one of the common ways to express the concentrations of solutions.
Since % means the number of grams of solute in 100 grams of solution (solute + solvent), a 1.5% solution of any solute refers to 1.5 grams of it in 100 grams of solution.
Assuming we are referring to an aqueous solution (that is, where water is the solvent), this reasonably approximates to 1.5 grams of lidocaine per 100 mL solution. We can assume this result, because we have a dilute watery solution, which probably has the density close to the density of pure water, which is 1.0 gram per 1.0 mL at commonly used temperatures, such as average room temperature.
So, 1.5 g lidocaine per 100 mL solution can easily be scaled down by one-tenth to give:
0.15 g lidocaine per 10 mL solution.
Posted on Jan 04, 2011
How many MG in a gram
MG = milligram = 1/1000 of the gram
Sep 19, 2015 | Office Equipment & Supplies
DOES Lidocaine patch 5% make you lose your hair
Hair loss is not noted as a side effect for this topical anesthetic.
http://goo.gl/EfQ8IM. You can also ask your pharmacist (free) and/or physician for information about side effects of this or any other prescriptions you're taking. You should always discuss any health issue with a healthcare professional.
Mar 01, 2015 | Computers & Internet
What is the useage per litre in mls or grams not ozs for concetrate
for annual weeds use a 1%solution and for brush and industrial right of way use 2%solution.1%=10ml per liter 2%=20ml per liter
May 16, 2014 | Roundup "" Weed & Grass Killer
10ml to onces
That depends on what you mean by "ounce."
10ml is about 0.34 US ounces or about 0.35 UK ounces.
Mar 15, 2014 | Office Equipment & Supplies
PH
That would depend on how much water you're adding to. Adding 10ml of HCl to a thimble of water is not the same thing as adding 10ml of HCl to a swimming pool.
May 22, 2013 | Office Equipment & Supplies
I'm getting about 10Ml/gal, is this normal or what could be a problem for such a low milage???Thanks for help
If you haven't done so recently then replace your air filter, that might help. You can also take the vehicle to autozone or any auto parts chain store that will run a diagnostic scan for free and see if any error codes are present and if there are they will tell you what parts may need replaced. You should be getting much better fuel mileage than that.
Mar 25, 2011 | 2000 Isuzu Rodeo
How much is 10ml to teaspoons
there are 5 mls per teaspoon, so 10ml is 2 teaspoons
May 11, 2010 | Health & Beauty
MPS Multimedia QuickStudy Chemistry for PC Logo
791 people viewed this question
Top MPS Multimedia Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a MPS Multimedia Computer and Internet Expert? Answer questions, earn points and help others
