Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
Television must be turned off But remain plugged in
First You must place both your fingers on the VOL + and VOL - buttons on the television.
Then Turn on the television while still holding the volume buttons in for about 6 seconds..
The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
My ancient TV/VCR Quasar combo had the same problem...and I don't have the original remote control. But holding down the "play" button for five seconds did the trick. Perhaps your TV is similar. I also read that holding down the "menu" button works as well. Hope this helps.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
4.
To stop the demonstration mode
• Press and hold stop (on the system
only) for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
