Display
Yes it is possible but....
Your laptop version may either be using an NVidia or an ATI. If an NVidia, right click on any clear area of your desktop, click on Properties, (in Display Properties) Settings, Advanced, TwinView tab, Clone, Apply, OK, Yes (if you want to keep this setting), OK.
Am not sure if it will work with the ATI version, right click on any clear area of your desktop, click on Properties, (in Display Properties) Settings, Advanced, Display, TV button, Primary (display only on projector) hope you have other setting like LCD + TV (display on both), Apply, Yes (if you want to keep this setting), OK.
Your Canon LV-S3 Multimedia Projector's Native resolution is 800x600 max @ 1280x1024 Pixels. You may need to set your laptop to the lowest first and gradually work it up till the projector no longer can display, then back down one notch.
You may also need to press on Fn + F8 a few times to check if you can switch displays: LCD, TV/projector, LCD + TYV/Projector.
You can try either the S-video TV-out connector or the video connector (both at the back).
Hope this be of help/idea. Post back how things turn up or should you need further information.
Good luck and kind regards.
