Refrigerators Logo
L
Laura Ann Shatzer Posted on Jan 13, 2024
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
I moved into a rental and I'm connecting the ice maker. I have the connection to the water supply set up. How do I connect the water supply using a plastic hose kit to the MBB1954G UNIT?
  • picasso appk
    picasso appk Oct 05, 2024
    To install the plastic water line for the Maytag MBB1954G ice maker, first, turn off the water supply. Attach the plastic line to the water inlet valve at the back of the fridge using a compression nut. Route the line through the back panel to the freezer and connect it to the ice maker. Secure all connections, then turn the water supply back on and check for leaks.https://picassoappk.net/
Don A
Level 3:
  • Maytag Master 4,969 Answers
  • Posted on Jan 14, 2024
Don A
Maytag Master
Level 3:
Answers
4969
Questions
5
Helped
1474933
Points
26840
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps:
Turn off the water supply valve under the sink.
Remove the old hose from the water supply valve and the back of the refrigerator.
Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted.
Tighten the fittings with an adjustable wrench.
Turn on the water supply valve and check for leaks.
Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
Top Maytag Refrigerators Experts
vince
Johnny 1000
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
