Question about Panasonic (TH-50PZ700U) Television
Panasonic th-50pz700u 50" plasma. All inputs seemed to have stopped working. HDMI/Component/CATV Tuner all either display black screen or static scramblemed Pink/Green lines. The menu on the TV still works fine and can be read without issue. Also the SD card reader works fine and will display pictures from an SD card without issue. Ive unplugged and tried to reset with no avail.
SOURCE: Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Posted on Dec 31, 2007
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: 1 yr old panasonic th-50pz700u
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Posted on Jun 21, 2009
Please dont forget to vote if you liked my answer
thanks
