Washing Machines Logo
A
Anonymous Posted on Dec 12, 2023
MY Samsung washing machine WD0804W8 ECO BOBBLE not working
When I turn it on and choose the program It start to fill the water but the drum not rotate I hear the motor but the drum can rotate .I tried to rotate the drum by hand after turn it off and it turn freely . I called the maintenance technician from Samsung Co. He came and start chek he pressed the spin button and dry botton together and we heard something blowed up inside the machine and screen turned of . I think he made a mistake when he tried to inter to test mode. Anybody can help me
ADMIN Eric
Level 3:
Top Expert:
  • Samsung Master 39,095 Answers
  • Posted on Dec 13, 2023
ADMIN Eric
Samsung Master
Level 3:
Top Expert:
Answers
39095
Questions
0
Helped
755617
Points
582837
Here is a list of issues that are common
https://www.samsung.com/uk/support/model/WD0804W8E1/XEU/
but you may need a replacement control panel now.
If water/liquids ingressed the control board or a bad connection on the board has happened, that is another probable cause.
Testimonial: "Thank you But I need to know the way to inter test mode is it true by pressing the spin and dry together?"
2helpful
Samsung eco bubble washer and dryer continues to fill with water till the top. Could it be that the sensor is not working?
If your Samsung Eco Bubble washer is filling with water till the top, it could be due to a faulty water inlet valve 1. You may need to replace the valve to get your appliance filling with water and working properly again .
However, if you suspect that the sensor is not working, you can try the following steps :
Check if the LED on the eco bubble wash button is on.
Check if there is too little laundry in the washing machine. In case of heavily soiled laundry, bubbles may not be generated very well.
Unplug the machine from the mains to ensure your safety.
Locate the two screws on the back of the machine that hold the top cover in place, and unscrew them.
Gently push the top cover back and remove it to expose the interior.
Take out the detergent container.
Identify and remove the screws that secure the front panel in place.
If none of these steps help, please contact a local Samsung service center
2answers
W/machine not filling with water
Also ...The selector switch allows you to choose the wash, rinse and spin settings. When you set the desired program, it sends a signal to the water inlet valve to open the hot and cold water inlets. If the selector switch is not powered or unable to transfer the signal, your washing machine won't fill with water.
SAMSUNG FRONT LOAD WASHER WF45K6200AW/A2 NOT FILL IN WATER
FIRST remove your water supply and check that the water flows correctly...
THEN...
Check you WATER SOLENOID...
Use your SCHEMATIC drawing to determine if the operating voltage is PRESENT
Answers:
YES = replace solenoid
NO = replace SCR on control board
(I think)
Are we having fun yet?
Carnac the Magnificent
Buttons all work but drum will not spin and it shows code f01
You dont mention make! Does it start program then shut off or does it fill then not turn? First part of any program is to pump out any water left from it previous program .if something is blocking pump (bra wire/coins/hair bobble etc) it will shut down and putup a code.if its the brushes in the motor or belt broken it will start then pump then fill then may carry through whole program as it doesnt know its drum isnt spinning.or it will detect and show fault code.replacing brushes in motor is for somebody who knows what theyre doing.but its straight forward and brushes are cheap. Pumps blocking again common but most people can clear a blockage via a door at bottom of machine.water will ome out so take drain tube and hold in a bucket at ground level first
Samsung ecobubble 7kg red drum flashes at end of cycle? Is it broken?
We have later model and have same flashing drum symbol. You need to perform an ECO DRUM CLEAN cycle.
1. Press power to turn on machine.
2. Turn cycle selector to ECO DRUM CLEAN mode
3. Press Start/pause
My Fisher Paykel 8kg Intuative Washing Machine doesn't work on the Eco Wash cycle
Your eco Diverter valve has failed. this is a wax solenoid and is a common part to fail, it is located under the machine in the drain hose next to the drain pump.
Check out the below link for a service manual
Link:
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
2answers
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Top Samsung Washing Machines Experts
Marvin
Marvin
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
