From the user manual:Feed and Pause self testperforming this self test temporarily resets the printer configuration to the factory default values. these values are active only until power is turned off unless you save them permanently in memory. If the factory default values are permanently save, a media calibration procedure must be performed.To perform a Feed and Pause self test, complete these steps:1. Turn off (O) the printer.2. Press and hold FEED and PAUSE while turning the power On (I)3. Hold FEED and PAUSE util the first control panel light turns off.the printer configuration is temporarily reset to the factory default values. No labels print at the end of this test.
Resets the printer to factory settings or calibrate the printer by pressing the FEED, PAUSE and CANCEL, turn the printer and release the keys when feeding the labels. Roberto Martinez
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS. Roberto Martinez
Let the printer calibrates itself or have a manual calibration in the printer setup. You can also press the keys FEED, PAUSE and CANCEL, turn on the printer and release the keys when feeding the labels. Roberto Martinez
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer. Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
