Hp laserjet 9000 printing blank across middle of page from left to right
We have two HP Laserjet 9000 printers. One is not printing the middle of the portrait page from left to right. I have swapped the toner, fuser, and transfer roller with the other printer one at a time and the problem stays the same. I do not see anything jammed in what I assume is the laser path above the toner.
Unfortunately, I got "SERVICE TEST PASSED" and the problem is still happening.Unfortunately, I got "SERVICE TEST PASSED" and the problem is still happening.
You can't post conmments that contain an email address.
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Does this happen both when copying and printing? For printing solution, try another toner cartridge. If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it. Read below:
Shown at left: HP LaserJet 9000 series, base unit—LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit + • HP
Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray LaserJet 9000dn = base unit + • HP Jetdirect 610n (EIO) internal
• 100-sheet multipurpose tray • Automatic duplex unit for two-sided printing
LaserJet 9000hns = base unit + • HP Jetdirect 610n (EIO) internal
print server for Ethernet 10/100Base-TX • Automatic duplex unit for two-sided printing
• 2000-sheet input tray
• 3000-sheet stapler/stacker
