Refrigerators Logo
Question about Danby Refrigerators
Danby Chest freezer leaking
I have a older Danby chest freezer DCF070A1WDB. It is NOT a self defrosting type. It is leaking water on the floor. I emptied it and looked under. There is no drip pan on this model. The underside is spongy and dripping from many spots? Why and is there any way to fix this? Valerie
Posted by Valerie on
ADMIN 61k
    Top Expert:
  • Danby Master
  • 61,568 Answers
No it is time for a new one. There is either a leak on the inner liner or the insulation between the inner layer and outer layer has broken down and is causing condensation.
Posted on Sep 11, 2023
Testimonial: "Thank you for the information, really appreciate knowing, although that wasn’t the answer I was hoping for of course ??"
  • ADMIN 61k
    ADMIN 61k Sep 13, 2023
    Plan B would be to empty it, tip it on its side, remove the spongy material, dry it and carefully apply expanded polyurethane foam. Remember it continues to expand for about 10 minutes so a thin layer to start with. Wear gloves. Put it the right way up and leave a couple of hours before turning back on to let the liquid gas settle. It will just cost you $8 for a can of foam. You can also check for cracks on the inner lining and fix with white kitchen/bathroom silicone. It is a cheaper fix and will last a few years.
2answers
Water is leaking out onto the floor from freezer
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
GE refrigerator mdl tbx18jabkrww is leaking from underneath the appliance. The appliance has an optional ice maker installed. Do you know what the issue could be?
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer. Take care in solving the problem....
Inside water dispenser is leaking
Hoping this will help to solve the problem....
Hi there, I have a MAYTAG MSD2758DR Refrigerator and every night water is leaking from front left and floor is getting wet. The amount of leaked water is nearly a cup of water.
Water leaking inside around the drain from the freezer, water collects in the bottom under the drawers
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
Hope this will help in solving the problem...
1helpful
Water freezes in bottom freezer and then leeks onto floor
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer if you can not handle it yourself..
Do take care in solving the problem....
1helpful
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 • Freezers
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 • Freezers
1helpful
2answers
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
2helpful
Danby freezer leaking water
there is a line from the freezer defrost pan to the evaporation pan at the bottom. They often get clogged with bugs, dirt,etcWhen that happens, the defrost pan overflows resulting with a spill of water. Find it, blow it free , and you should be OK.good luck, John
Open Questions:
Top Danby Refrigerators Experts
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
