TH-32D310Q
If the green light is flashing on your Panasonic TV and it won't turn on, it usually indicates that there is a problem with the TV's power supply. Here are some troubleshooting steps you can try:
Unplug the TV from the power outlet and wait for a few minutes before plugging it back in. This will allow the TV to reset.
Check the power cord and make sure it is securely plugged into the TV and the power outlet. If the cord is damaged, replace it.
Check the power outlet by plugging in another device to see if it works. If the outlet is not working, try plugging the TV into a different outlet.
If the above steps do not work, you may need to contact a professional technician to diagnose and repair the TV. It could be an issue with the power supply or other internal components.
I hope these steps help you resolve the issue with your Panasonic TV.
