Hello If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following. [1] Unplug the power cord from wall outlet. [2] Make sure that the projector has cooled off. [3] Plug the power cord into the wall socket. [4] Press the power button. Check whether the cooling fan has stopped. The problem is with overheating itself. If these does not help you, your projector need service. OK.
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
if the buttons don't work or the leds are not on the projector, it has a power problem. make sure the outlet for the projector is functioning. if still nothing, the bimetal breaker on the projector may have tripped due to overheating. you'll need to remove the top cover. the bimetal has a small red button and is located on the lamp housing. push in the button to reset it. also make sure that the lamp door and the lens cover are completely installed and that the blue switches for them are not broken. this will also cause it not to turn on.
The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service.
A copy of your manual is available at
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf
Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
