Televison & Video Logo
Frank Skead Posted on Mar 18, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tedelex intellipower 4, 24v DC inverter. I need a owners manual for it please.
ADMIN Andrew
Level 3:
Top Expert:
  • Televison & ... Master 66,963 Answers
  • Posted on Mar 18, 2023
ADMIN Andrew
Level 3:
Top Expert:
Answers
66963
Questions
Helped
5087054
Points
379812
Question edited for clarity 'cd' to 'DC'.
Try the link. It appears to be South African, and we are in North America.
https://www.google.com/search?q=Tedelex+intellipower+4%2C+24v+DC+inverter
tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
I need an owners' manual for tedelex intellipower usb inverter please
MFG web site is primo choice, the google for it if no luck.
2helpful
My tedelex intellipower 600w inverter in working order, tested and told it is dangerous and irreparable, your opinion please
It's shorted to ground somewhere. It's probably not worth while to have a professional repair it, but you might take it apart yourself and see what's what inside if you're handy with a multimeter.
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Tedelex manual
Where can I purchase a tedelex Y sus board in Durban, urgent
1helpful
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
2answers
Manual, for a aims 1500 pure sine inverter, not putting out. need manual or help in diagnosing the problem
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here: http://www.psui.com/pdf/75-1000-0001.pdf
Regards.
Jun 04, 2011 • Vacuums
1helpful
Safety Inquiry
Improper use of a power inverter could result in personal injury. The inverter should not be installed in the vehicle’s engine compartment. Keep the inverter free from moisture as liquids conduct electricity, which may lead to serious damage or injury! Do not use the inverter near flammable materials or where fumes or gases may accumulate. The AC Output (neutral) wire should be vonded to ground, except in special applications. See owner’s manual for more details.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
