Question edited for clarity and make some sentences.
All questions need FULL 'make mode (what it is)' as first 3 words.
Is is a Samsung? It can't connect to the Internet. That is normally so you can control it from work and alter it when you leave. For the tripping, try disconnecting the power for an hour to reset it. That may need dealer service. The compressor restarting is called 'short cycling', but they should trip unless you have something else on the same circuit. The one that was in our bedroom would trip if my wife used the hairdryer in the bathroom. They draw a lot of power.
As others have pointed out, it means that it can't reach the internet. I see this routinely on a certain network which requires additional credentials to be entered before giving full access.
My Samsung AC has a WiFi symbol near the on button. Does ...
and
What are Wi-Fi enabled air conditioners (ACs)?
Reliance Digital
https://www.reliancedigital.in > Home > Buying Guides
Enter the login credentials and you will be prompted to select the AC model. The app will then pair the phone with the air conditioner, via the Wi-Fi router.
