Hi Arnold Loucks, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What is the make and model? There are hundreds of kinds of watches on the market, and dozens of setting systems.Hi Arnold Loucks, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Hey, if it is an analog watch, pull out the crown twice if you can and turn it to set the time, if its digital it has buttons on the side to set the time.
yes, the problem is the battery of your watch. it is brand new but many of brand new watch sat on their selling showcases for a long time that when the time you were about to purchase it,it has low battery charged. you have to bring it back from where you bought it, and they have to change the battery. i hpoe i helped you.
To change your Armitron WR165 watch from military time (also known as 24-hour time) to 12-hour time, you will need to follow these steps:
Press and hold the "mode" button until the display shows the current time format (either 12H or 24H).
Press the "set" button to toggle between the two time formats.
When the desired time format is displayed, press the "mode" button to exit the setting mode and save the new time format.
If you are having trouble changing the time format on your watch, you may want to consult the user manual for your specific model, as the steps may vary slightly depending on the version of the watch you have. You can also try contacting Armitron customer support for further assistance.
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at [email protected], or by phone at 1-888-459-0404.
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
